- UNC PAth 问题? 1个回答
An error occurred while starting the solver module. Verify that your solver directory does not reside on a network UNC Path. Please refer to the Troubleshooting section in the ANSYS Mechanical User Gu
- abaqus后处理path选点不全 3个回答
abaqus后处理用path选择路径上所有点总会漏掉几个,求解决办法
- 静力学分析时,遇到“you need a valid path to proceed with the solutions” 2个回答
静力学分析时,求解“Total Shear-Moment Diagram”时,出现you need a valid path to proceed with the solutions问题,其中details of “Total Shear-Moment Diagram”中的path没法编辑。。。 请问各位老师,这个问题如何解决~ 菜鸟一枚,求解。。。谢谢!!
