各位大佬,新手abaqus分析错误,求教,怎么解决啊
浏览:5183 回答:8
in keyword *COUPLING, file "Job-2.inp", line 35443: Unknown assembly set M_SET-5
Node set assembly_m_set-5 has not been defined
Unable to locate node set assembly_m_set-5. The node set must have been previously defined.
The reference node 0 on the *coupling option is not defined.
1008 nodes are used more than once as a slave node in *TIE keyword. These constraints are not removed either due to the presence of *CONSTRAINT CONTROLS,NO CHANGES keyword or because removing the constraints might affect the model. The nodes have been identified in node set ErrNodeOverconTieSlave.
840 nodes may not be used with a multi-point constraint since they are also part of pretension section. The nodes have been identified in node set ErrNodeMPCPretenSec.
Analysis Input File Processor exited with an error.
Mr dazzle
编辑关键字里找到截面的关键字section。删掉ref node=Part-1-1-RefPt_。该错误可能是因为模型没有可供指派的参考点
2024年3月21日
海之精灵
在odb里查看这两个set集ErrNodeOverconTieSlave ErrNodeMPCPretenSec,就知道错误出在哪了
2019年7月25日
海之精灵
看样子好像是你没定义set集m_SET-5。有可能是你重新划分网格之后就清除掉了
2019年7月25日
评论 4 点赞
