abaqus中能不能同时添加两个不同刚度的非线性弹簧? 20
浏览:1936 回答:2
模型需要添加两个不同刚度的非线性弹簧,但是通过inp文件添加后,出现冲突错误,如下所示:
in keyword *CONFLICTS, file "1.inp", line 208901: Keyword *Conflicts is generated by Abaqus/CAE to highlight changes made via the Keywords Editor that conflict with changes made subsequently via the native GUI.
in keyword *CONFLICTS, file "1.inp", line 208903: Keyword *Conflicts is generated by Abaqus/CAE to highlight changes made via the Keywords Editor that conflict with changes made subsequently via the native GUI.
in keyword *CONFLICTS, file "1.inp", line 208905: Keyword *Conflicts is generated by Abaqus/CAE to highlight changes made via the Keywords Editor that conflict with changes made subsequently via the native GUI.
in keyword *CONFLICTS, file "1.inp", line 208901: The keyword is misplaced. It can be suboption for the following keyword(s)/level(s):
Analysis Input File Processor exited with an error.
删掉冲突词条不起作用,而且提示其中一个非线性弹簧语句错误,如果改成相同刚度的两个非线性弹簧或者两个不同刚度的线性弹簧,则运行时无错误提示
请问是什么原因?
寒江雪_123
答案是可以。同时删掉*conflict一定是有用的,你感觉没有用可能是因为没有正确地操作,比如操作的是inp文件而job却是基于model而没有基于inp
2019年8月20日
已采纳 评论 1 点赞 1
