ANSYS workbench 划分网格出错,怎么回事,本人新手,求大神解答?
浏览:12532 回答:3
部分零件导入后变成了好多零件,用unfreeze功能将他们重新合并,出现网格划分出错不知道是不是跟这个也有关系。
网格划分的方法采用的自动划分。
在geometry中看到,除了一个零件前是√,其余都是半勾。
划分结果:
错误提示如下:
The mesher restarted at a higher relevance in order to achieve a successful, quality mesh.
One or more entities failed to mesh. The mesh of the bodies containing these entities may not be up-to-date. However, meshing might be successful on the other entities.
The surface mesh is intersecting or close to intersecting, making it difficult to create a volume mesh. Please adjust the mesh size or adjust the geometry to fix the problem.
A mesh could not be generated using the current meshing options and settings.
楼主,我遇到跟你相同的问题,请问你解决了吗
