abaqus 的python 二次开发问题? 20
浏览:1802
no modules named abaqus 是什么原因,求解答,真的快疯了,我在百度上也看了很多,试了很多,还下载了所谓的abaqus.py这样的文件,然后这个问题没了,可是出现了新的问题。
Traceback (most recent call last):
  File "D:/abaqus6.14/6.14-1/code/python2.7/lib/a.py", line 11, in <module>
    from abaqus import *
  File "SMAPyaModules\SMAPyaAbqPy.m\src\abaqus.py", line 5, in <module>
  File "SMAPyaModules\SMAPyaUtilsPy.m\src\i18n.py", line 1, in <module>
  File "SMAPyaModules\SMAPyaUtiPy.m\src\uti.py", line 5, in <module>
  File "SMAPyaModules\SMAPyaUtiPy.m\src\utiinternal.py", line 52, in <module>
  File "SMAPyaModules\SMAPyaUtiPy.m\src\uticty.py", line 145, in <module>
  File "SMAPyaModules\SMAPyaUtiPy.m\src\uticty.py", line 136, in _loadAbaqusDll
ValueError: dll not found: ABQSMABasShared.dll
>>>这样的问题又出现了。如果可以希望能人志士远程搞一下,价格可商议。
