为什么Patran没有op2文件产生呢?
本人初学,做了一个静力分析的练习,建模,网格划分,边界约束,材料设定,属性设定后,调用Nastran分析总是没有.op2文件产生,下面是命令行内容
xp系统,安装的2005r3版Patran,没有安装Nastran
$# The NASTRAN input file, test.bdf, has been successfully opened.
$# Translating 50 elements from the element property region p1.
$# 1 property regions translated.
$# Translating 1 referenced material records.
$# Translating 66 nodes from the entire model.
$# Writing loads for Load Case : Default.
$# Translating nodal constraints in load set : d1.
$# Writing interface element lbcs.
$# Translating nodal forces in load set : f1.
$# Total execution time in real seconds: 1
$# Total execution time in CPU seconds: 0.0630001
$# End of NASTRAN input file translation.
$# MSC.Patran Nastran Preference 2005 r3 has released 1 license(s) to FLEXlm
$# at 14-Mar-07 21:01:25.
$# The translation has completed successfully.
$# Executing d:\MSC.Software\MSC.Patran\2005_r3\bin\exe\MscNastranExecute.exe
分析设置时,要选择输出文件格式时op2的,这样才能输出你需要的格式文件.
可能是你的patran的求解路径没有指向nastran.所以出现问题.你patran安装路径(如:D:\MSC\patran2004)下面的P3_TRANS.INI文件中所寻找的nastran路径一定要正确.
(Alocalcommand2004=D:\MSC\bin\nastran.exe(这个即使nastran的安装路径.)
Acommand2004=D:\MSC\bin\nastran.exe)
