拓扑优化经典99行程序解读
浏览:36723 评论:4 收藏:2
Sigmund教授所编写的top优化经典99行程序,可以说是我们拓扑优化研究的基础;
每一个新手入门都会要读懂这个程序,才能去扩展,去创新;
99行程序也有好多个版本,用于求解各种问题,如刚度设计、柔顺机构、热耦合问题,但基本思路大同小异;
本文拟对其中的一个版本进行解读,愿能对新手有点小小的帮助。
不详之处,还请论坛内高手多指点
读懂了该程序,只能说是略懂拓扑优化理论了,
我手里就有一些水平集源程序是成千上万行,虽然在99行的基础上成熟了很多,但依然还有很多的发展空间。
源程序如下:
%%%% A 99 LINE TOPOLOGY OPTIMIZATION CODE BY OLE SIGMUND, JANUARY 2000 %%%
%%%% CODE MODIFIED FOR INCREASED SPEED, September 2002, BY OLE SIGMUND %%%
function top(nelx,nely,volfrac,penal,rmin);
nelx=80;
nely=20;
volfrac=0.4;
penal=3;
rmin=2;
% INITIALIZE
x(1:nely,1:nelx) = volfrac;
loop = 0;
change = 1.;
% START ITERATION
while change > 0.01
loop = loop + 1;
xold = x;
% FE-ANALYSIS
=FE(nelx,nely,x,penal);
% OBJECTIVE FUNCTION AND SENSITIVITY ANALYSIS
[KE] = lk;
c = 0.;
for ely = 1:nely
for elx = 1:nelx
n1 = (nely+1)*(elx-1)+ely;
n2 = (nely+1)* elx +ely;
Ue = U([2*n1-1;2*n1; 2*n2-1;2*n2; 2*n2+1;2*n2+2; 2*n1+1;2*n1+2],1);
c = c + x(ely,elx)^penal*Ue'*KE*Ue;
dc(ely,elx) = -penal*x(ely,elx)^(penal-1)*Ue'*KE*Ue;
end
end
% FILTERING OF SENSITIVITIES
[dc] = check(nelx,nely,rmin,x,dc);
% DESIGN UPDATE BY THE OPTIMALITY CRITERIA METHOD
[x] = OC(nelx,nely,x,volfrac,dc);
% PRINT RESULTS
change = max(max(abs(x-xold)));
disp([' It.: ' sprintf('%4i',loop) ' Obj.: ' sprintf('%10.4f',c) ...
' Vol.: ' sprintf('%6.3f',sum(sum(x))/(nelx*nely)) ...
' ch.: ' sprintf('%6.3f',change )])
% PLOT DENSITIES
colormap(gray); imagesc(-x); axis equal; axis tight; axis off;pause(1e-6);
end
%%%%%%%%%% OPTIMALITY CRITERIA UPDATE %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
function [xnew]=OC(nelx,nely,x,volfrac,dc)
l1 = 0; l2 = 100000; move = 0.2;
while (l2-l1 > 1e-4)
lmid = 0.5*(l2+l1);
xnew = max(0.001,max(x-move,min(1.,min(x+move,x.*sqrt(-dc./lmid)))));
if sum(sum(xnew)) - volfrac*nelx*nely > 0;
l1 = lmid;
else
l2 = lmid;
end
end
%%%%%%%%%% MESH-INDEPENDENCY FILTER %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
function [dcn]=check(nelx,nely,rmin,x,dc)
dcn=zeros(nely,nelx);
for i = 1:nelx
for j = 1:nely
sum=0.0;
for k = max(i-floor(rmin),1):min(i+floor(rmin),nelx)
for l = max(j-floor(rmin),1):min(j+floor(rmin),nely)
fac = rmin-sqrt((i-k)^2+(j-l)^2);
sum = sum+max(0,fac);
dcn(j,i) = dcn(j,i) + max(0,fac)*x(l,k)*dc(l,k);
end
end
dcn(j,i) = dcn(j,i)/(x(j,i)*sum);
end
end
%%%%%%%%%% FE-ANALYSIS %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
function =FE(nelx,nely,x,penal)
[KE] = lk;
K = sparse(2*(nelx+1)*(nely+1), 2*(nelx+1)*(nely+1));
F = sparse(2*(nely+1)*(nelx+1),1); U = zeros(2*(nely+1)*(nelx+1),1);
for elx = 1:nelx
for ely = 1:nely
edof = [2*n1-1; 2*n1; 2*n2-1; 2*n2; 2*n2+1; 2*n2+2; 2*n1+1; 2*n1+2];
K(edof,edof) = K(edof,edof) + x(ely,elx)^penal*KE;
end
end
% DEFINE LOADS AND SUPPORTS (HALF MBB-BEAM)
F(2*(nelx/2+1)*(nely+1),1) = 1;
fixeddofs = [2*(nely/2+1),2*nelx*(nely+1)+2*(nely/2+1)];
alldofs = [1:2*(nely+1)*(nelx+1)];
freedofs = setdiff(alldofs,fixeddofs);
% SOLVING
U(freedofs, : )= K(freedofs,freedofs) \ F(freedofs,: );
U(fixeddofs,: )= 0; % 这两行复制后应换成英文字符,我这里为了防止生成QQ表
% 情修改了一下格式
%%%%%%%%%% ELEMENT STIFFNESS MATRIX %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
function [KE]=lk
E = 1.;
nu = 0.3;
k=[ 1/2-nu/6 1/8+nu/8 -1/4-nu/12 -1/8+3*nu/8 ...
-1/4+nu/12 -1/8-nu/8 nu/6 1/8-3*nu/8];
KE = E/(1-nu^2)*[ k(1) k(2) k(3) k(4) k(5) k(6) k(7) k(8)
k(2) k(1) k(8) k(7) k(6) k(5) k(4) k(3)
k(3) k(8) k(1) k(6) k(7) k(4) k(5) k(2)
k(4) k(7) k(6) k(1) k(8) k(3) k(2) k(5)
k(5) k(6) k(7) k(8) k(1) k(2) k(3) k(4)
k(6) k(5) k(4) k(3) k(2) k(1) k(8) k(7)
k(7) k(4) k(5) k(2) k(3) k(8) k(1) k(6)
k(8) k(3) k(2) k(5) k(4) k(7) k(6) k(1)];
程序执行方法:(just for matlab new users)
打开matlab,点开new M-file,将上述源程序复制粘贴到M-文件中,修改蓝色部分的格式,保存。按F5即可执行~~
程序个人解读(会针对大家的提问,高手们的解释,不断补充更新):
主程序部分:
包括: 数据初始化;有限元分析;敏度分析,OC算法,结果显示
nelx=80; % x轴方向的单元数
nely=20; % y轴方向单元数
volfrac=0.4; %体积比
penal=3; %材料插值的惩罚因子
rmin=2; %敏度过滤的半径
% INITIALIZE
x(1:nely,1:nelx) = volfrac; %x是设计变量
loop = 0; %存放迭代次数的变量
change = 1.; %每次迭代目标函数的改变值,用以判断何时收敛
% START ITERATION
while change > 0.01 %当两次连续目标函数迭代的差小于等于0.01时,结束迭代
loop = loop + 1; %迭代次数加1
xold = x; %把前一次的设计变量赋值给xold
% FE-ANALYSIS
=FE(nelx,nely,x,penal); %进行有限元分析
[KE] = lk; %单元刚度矩阵
c = 0.; %用来存放目标函数的变量.这里目标函数是刚度最大,也就是柔
%度最小
for ely = 1:nely
for elx = 1:nelx
c = c + x(ely,elx)^penal*Ue'*KE*Ue; %计算目标函数的值(即柔度
%是多少)
dc(ely,elx) = -penal*x(ely,elx)^(penal-1)*Ue'*KE*Ue; % 灵敏度分析的结果 这一行
%和上一行可参考论文中的公式
end
end
[dc] = check(nelx,nely,rmin,x,dc); %灵敏度过滤,为了边界光顺一点
[x] = OC(nelx,nely,x,volfrac,dc); %优化准则法更新设计变量
% PRINT RESULTS
change = max(max(abs(x-xold))); %计算目标函数的改变量
' ch.: ' sprintf('%6.3f',change )]) %屏幕上显示迭代信息
% PLOT DENSITIES
colormap(gray); imagesc(-x); axis equal; axis tight; axis off;pause(1e-6); %优化结果的图形显示(个人认为这种图形显示方法很不好,太简单了。比较方便的图形显示应该是:
每一次迭代同时显示优化结果、目标函数曲线,然后自动保存每一次的结果)
end
OC算法子程序:
l1 = 0; l2 = 100000; move = 0.2; %l1,l2用于体积约束的拉格朗日乘子
lmid = 0.5*(l2+l1);
xnew = max(0.001,max(x-move,min(1.,min(x+move,x.*sqrt(-dc./lmid))))); %这里是OC算法的核心所在,具体含义可参考论文中的公式
if sum(sum(xnew)) - volfrac*nelx*nely > 0; %采用了二乘法更新拉格朗日乘子
l1 = lmid;
else
l2 = lmid;
end
end
敏度过滤技术子程序:
for i = 1:nelx
for j = 1:nely
sum=0.0;
end
end
end
end
这一段就不多解释了,只是为了光顺边界的,现在二重敏度过滤技术用得更多一点了。理论部分可参考罗震博士的毕业论文
看不懂的代码在matlab命令窗口输入:help XXX(即你看不懂的那个关键词,比如这里的floor)
有限元求解子程序
[KE] = lk; %单元刚度矩阵
K = sparse(2*(nelx+1)*(nely+1), 2*(nelx+1)*(nely+1)); %总体刚度矩阵的稀疏矩阵
F = sparse(2*(nely+1)*(nelx+1),1); U = zeros(2*(nely+1)*(nelx+1),1); %力矩阵的稀疏矩阵
for elx = 1:nelx
for ely = 1:nely
edof = [2*n1-1; 2*n1; 2*n2-1; 2*n2; 2*n2+1; 2*n2+2; 2*n1+1; 2*n1+2]; %这里的Y轴是反向的,但是不影响最后的结果,详情请见二楼TYNGOD这位高手的解释,感谢TYNGOD。
K(edof,edof) = K(edof,edof) + x(ely,elx)^penal*KE; %将单元刚度矩阵组装成总的刚度矩阵
end
end
F(2*(nelx/2+1)*(nely+1),1) = 1; %初始的集中力
fixeddofs = [2*(nely/2+1),2*nelx*(nely+1)+2*(nely/2+1)]; %固定结点
alldofs = [1:2*(nely+1)*(nelx+1)]; %所有结点
freedofs = setdiff(alldofs,fixeddofs); %自由节点
% SOLVING
U(freedofs,:) = K(freedofs,freedofs) \ F(freedofs,:); %有限元求解:位移场
U(fixeddofs,:)= 0; %固定节点位移为0
单元刚度矩阵的子程序:
function [KE]=lk
E = 1.;
nu = 0.3;
这里不解释,自己可查有限元理论。个人认为这里的单元刚度求解不是很好。
最后是我的运行结果:
优化结果:
论文:A 99 line topology optimization code written in Matlab
不详之处,还请论坛内高手多指点
源程序如下:
nelx=80;
nely=20;
volfrac=0.4;
penal=3;
rmin=2;
% INITIALIZE
loop = 0;
change = 1.;
% START ITERATION
while change > 0.01
loop = loop + 1;
xold = x;
% FE-ANALYSIS
[KE] = lk;
c = 0.;
for ely = 1:nely
for elx = 1:nelx
end
end
% PRINT RESULTS
% PLOT DENSITIES
end
lmid = 0.5*(l2+l1);
l1 = lmid;
else
l2 = lmid;
end
end
for i = 1:nelx
for j = 1:nely
sum=0.0;
end
end
end
end
[KE] = lk;
for elx = 1:nelx
for ely = 1:nely
end
end
% SOLVING
% 情修改了一下格式
function [KE]=lk
E = 1.;
nu = 0.3;
主程序部分:
nelx=80; % x轴方向的单元数
nely=20; % y轴方向单元数
volfrac=0.4; %体积比
penal=3; %材料插值的惩罚因子
rmin=2; %敏度过滤的半径
% INITIALIZE
% START ITERATION
% FE-ANALYSIS
[KE] = lk; %单元刚度矩阵
%度最小
for ely = 1:nely
for elx = 1:nelx
%是多少)
%和上一行可参考论文中的公式
end
end
% PRINT RESULTS
% PLOT DENSITIES
end
OC算法子程序:
lmid = 0.5*(l2+l1);
l1 = lmid;
else
l2 = lmid;
end
end
敏度过滤技术子程序:
for i = 1:nelx
for j = 1:nely
sum=0.0;
end
end
end
end
有限元求解子程序
[KE] = lk; %单元刚度矩阵
for elx = 1:nelx
for ely = 1:nely
end
end
% SOLVING
单元刚度矩阵的子程序:
function [KE]=lk
E = 1.;
nu = 0.3;
最后是我的运行结果:
优化结果:
