CFX学习案例:烟囱排入大气流场计算
本案例将学习以下内容:
LIBRARY: &replace ADDITIONAL VARIABLE: smoke Option = Definition Tensor Type = SCALAR Units = [kg m^-3] Variable Type = Volumetric END END
首先对稳态数值计算进行设置,计算域的设置包含附加变量的相关设置:
标签 |
设置 |
值 |
Basic Settings |
Location and Type> Location |
B1.P3 |
Fluid and Particle Definitions |
Fluid 1 |
0 [atm] |
Heat Transfer > Option |
None |
Additional Variable Models > Additional Variable | smoke | |
Additional Variable Models > Additional Variable > smoke | (Selected) | |
Additional Variable Models > Additional Variable >smoke > Kinematic Diffusivity | (Selected) | |
Additional Variable Models> Additional Variable > smoke > Kinematic Diffusivity > Kinematic Diffusivity | 1.0E-5[m^2 s^-1](代表烟雾在空气中运动扩散速率) |
空气进口边界条件的创建及设置:Insert > Boundary >Set Name to Wind
标签 |
设置 |
值 |
Boundary Type |
Inlet |
Location |
Wind | |
Mass and Momentum > Option |
Cart. Vel. Components |
Mass and Momentum > U |
1 [m s^-1] |
Mass and Momentum > V |
Mass and Momentum > W |
0 [m s^-1] |
Turbulence > Option | Intensity and Length Scale | |
Turbulence > Fractional Intensity | 0.05 | |
Turbulence > Eddy Length Scale | 0.25 [m] | |
Additional Variables > smoke > Option | Value | |
Additional Variables > smoke > Add. Var. Value | 0 [kg m^-3] |
大气开放边界条件的创建及设置:Insert > Boundary >Set Name to Atmosphere。
标签 |
设置 |
值 |
Boundary Type |
Opening |
Location |
Atmosphere | |
Opening Pres. and Dirn |
Mass and Momentum > Relative Pressure | 0 [Pa] |
Flow Direction > Option |
烟雾进口边界条件的创建及设置:Insert > Boundary >Set Name to Vent。
标签 |
设置 |
值 |
Boundary Type |
Inlet |
Location |
Vent | |
Mass And Momentum > Normal Speed |
0.01 [m s^-1] |
Turbulence > Option | Turbulence > Option | Intensity and Eddy Viscosity Ratio |
初始值按照默认给定即可。
求解控制的设置:
标签 |
设置 |
值 |
Advection Scheme > Option |
High Resolution |
Convergence Control > Max. Iterations |
75 |
Convergence Control > Fluid Timescale Control >Timescale Control |
Auto Timescale |
Convergence Control > Fluid Timescale Control > Timescale Factor |
1.0 |
Convergence Criteria > Residual Type |
Convergence Criteria > Residual Target |
通过上述步骤完成了稳态的计算设置,接下来将稳态计算的设置复制一个,进行修改完成对瞬态计算的设置。
瞬态计算总时间为30 s,时间步长设置为4*0.25, 2*0.5, 2*1, 13*2 s,这样设置是给定了变化的时间步长,即第一秒的时间步长为0.25 s,第二秒的时间步长为0.5 s,以此类推。为方便更改,先创建表达式ExpFunction对烟雾进口(Vent)烟雾的流量进行定义。
LIBRARY: CEL: &replace EXPRESSIONS: ExpFunction = FinalConcentration*abs(1-exp(-t/TimeConstant)) FinalConcentration = 1 [kg m^-3] TimeConstant = 3 [s] END END END
在烟雾进口(Vent)边界条件中,将流速更改为0.2 [m s^-1],并将添加的附加变量smoke进行更改,Additional Variables > smoke > Add. Var. Value > ExpFunction。
在求解设置中,将最大迭代次数设置为3,即Convergence Control > Max. Coeff. Loops to 3。
在输出控制中,在瞬态结果中设置两个瞬态结果输出,在输出变量中给定Pressure,Velocity,smoke,第一个瞬态结果输出(Transient Results 1)中给定时间列表(Time List)为1, 2, 3 s,第二个瞬态结果输出(Transient Results 2)中给定时间间隔(Time Interva)为4 s。
基于以上设置完成了对稳态与瞬态计算的设置,接下来对计算的配置(Configuration )进行设置。分别创建两个计算配置,即Simulation Control > Configurations and select Insert > Configuration > Set Name to Steady State/Transient。在Steady State中,稳态布局对应稳态计算的设置部分,即Flow Analysis选择Steady State Analysis,Activation Conditions > Activation Condition 1 > Option选择Start of Simulation;在Transient中,瞬态布局对应瞬态计算的设置部分,并设置接着稳态计算结束后计算,即Flow Analysis选择Transient Analysis,Activation Conditions > Activation Condition 1 > Option选择End of Simulation,Activation Conditions > Activation Condition 1 > Configuration Name选择Steady State,并在Initial Values中选择稳态计算的结果作为初始值。设置完成后输出计算文件(CircVent.mdef)并开始计算即可。
计算结果:
以下内容为付费内容,请购买后观看
包含1个文件 1人购买
相关设置文件与结果文件
