基于LS-DYNA的SPG(Smoothed Particle Galerkin)资料收集
[1]Smoothed Particle Galerkin Method for Severe Deformation and Failure Analyses in Solids
[2]Modeling of Ductile Failure in Destructive Manufacturing Processes Using the Smoothed Particle Galerkin Method, Shanghai, 2017
[3]Parametric and Convergence Studies of the Smoothed Particle Galerkin (SPG) Method in Semi-brittle and Ductile Material Failure Analyses, Detroit, 2018
Semi-brittle and Ductile Material Failure Analyses.pdf
[4]The Immersed Smoothed Particle Galerkin Method in LS_DYNA for Material Failure Analysis of Fiber-Reinforced Solid Structures, Detroit, 2018
[5]An introduction to the LS-DYNA smoothed particle Galerkin method for severe deformation and failure analysis in solids
severe deformation and failure analysis in solids.pdf
官方提供的几个案例(包含说明文件和k文件),我摘过来
[1] example rod tensile
[2]Taylor impact
[3]Grinding
[4]Aluminium impact
全部评论 (0)
