ABAQUS计算报错,错误代码:529697949 解决方案
2020年6月4日 17:50浏览:5043 评论:4
ABAQUS在提交计算之后报错:
The executable standard.exe aborted with system error code 529697949. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job Job-lastmodal2 aborted due to errors.
解决方案:
重新提交计算/换台电脑计算都不行,换了内存比较大的工作站,计算OK!
