ANSYS知识库 | 软件报错信息和解决方法集:Maxwell相关(二)
3、Maxwell计算时提示“Fail to check out HPCPack License”?
问题描述:Maxwell正常计算时,在“Message”栏弹出对话框,提示“Fail to check out HPCPack License”,软件无法正常计算。
解决办法,需要确定如下license文件以及配置合理:
检查Maxwell License文件,确定已购买HPCPack License
打开Maxwell工具栏“Tools->Options->HPC and Analysis Options->Options-> HPC license”
4、Maxwell2d 求解报错
报错场景:Maxwell V2015 2D,求解时报错:[error] Maxwell2d solver, process solver2d error: Internal Solver Error: 'Force/torque can not be calculated well inside the moving parts! The enclosing object (band subtracted by moving objects) might not have triangles. Make sure that there is at least>
错误原因;外转子模型band设置
解决办法:修改外转子Band的建模。外转子的内外两边都要有间隙。如下图
点赞 16 评论 9 收藏 5
查看更多评论 >
