第二篇:2d杆单元
序:我要写一期python和Abaqus与有限元的文章,从弹簧单元、杆单元一直到实体单元,通过简单的实例用python编程,Abaqus验证结果。
1d杆单元类似于上篇提过的弹簧单元,这里不再写了,直接上手2d杆单元。杆单元刚度矩阵推导过程中需要遵守以下假定:
1)杆不能承受剪力或弯矩
2)忽略横向位移影响
3)遵守胡克定律
4)杆中间无外载
:图示桁架与弹簧系统,已知桁架E=210GPa,A=0.0005m2,具体载荷如下图所示,求:a)总刚;b)节点位移;c)单元应力。
第二篇:2d杆单元的图1
一、有限元法求解
步骤1:离散化
单元
节点i
节点j
步骤2:写单刚
单元1
θ=135°,cosθ=-0.707,sinθ=0.707
第二篇:2d杆单元的图2
求解上式,得
第二篇:2d杆单元的图3
同理,
第二篇:2d杆单元的图4
第二篇:2d杆单元的图5
步骤3:写总刚
第二篇:2d杆单元的图6
步骤4:边界条件
第二篇:2d杆单元的图7
本例中,u2=v2=u3=v3=u4=v4=0,F1x=0,F1y=-1000N,代入上述方程
步骤5:求方程,解u1和v1
利用上述方程不难解出u1=-0.095mm,v1=-0.19mm,具体不再赘述。
步骤6:后处理,求单元1应力单元2应力
取出相应的方程可求得σ1=2.8Mpaσ2=-2Mpa。
二、python求解
import numpy as np
import math
# 离散化
dimen = 2  # 2d
x1 = 0
x2 = -5 * math.sqrt(2) / 2
x3 = -10
x4 = 0
y4 = -10
y1 = 0
y2 = 5 * math.sqrt(2) / 2
y3 = 0
k4 = 1000
ele_node = np.array([[1, 2], [1, 3], [1, 4]])
node_coord = n
p.array([[x1, y1], [x2, y2], [x3, y3], [x4, y4]])
# 计算单刚
E = 210 * 10 ** 9
A = 0.0005
L1 = math.sqrt((x2 - x1) ** 2 + (y2 - y1) ** 2)
L2 = math.sqrt((x3 - x1) **
2 + (y3 - y1) ** 2)
def fun(C, S):
    Ke = np.array([[C * C, C * S, -C * C, -C * S], [C * S,
S * S, -C * S, -S * S],
                   [-C * C, -C * S, C * C, C * S],
                   [-C * S, -S * S, C * S, S * S]])
return Ke
def fun1(theta):
    x = theta * math.pi /
180
return x
theta1 =
135
x1 = fun1(theta1)
C1 =
round(math.cos(x1),15)
S1 =
round(math.sin(x1),15)
theta2 =
180
x2 = fun1(theta2)
C2 =
round(math.cos(x2),2)
S2 =
round(math.sin(x2),2)
theta3 =
270
x3 = fun1(theta3)
C3 =
round(math.cos(x3),2)
S3 = math.sin(x3)
T1 = fun(C1, S1)
T2 = fun(C2, S2)
T3 = fun(C3, S3)
k1 = E * A /
L1 * T1
k2 = E * A / L2 * T2
k3 = k4 * T3
# print(k1)
# print(k2)
# print(k3)
总自由度数
ndof = dimen * len(node_coord)
# 初始化总刚
K = np.zeros((ndof, ndof))
# 计算总刚
def fun2(K, k, i, j):
    K[
2 * i - 2, 2 * i - 2] = K[2 * i - 2, 2 * i - 2] + k[0, 0]
    K[
2 * i - 2, 2 * i-1] = K[2 * i - 2, 2 * i-1] + k[0, 1]
    K[
2 * i - 2, 2 * j - 2] = K[2 * i - 2, 2 * j - 2] + k[0, 2]
    K[
2 * i - 2, 2 * j-1] = K[2 * i - 2, 2 * j-1] + k[0, 3]
    K[
2 * i-1, 2 * i - 2] = K[2 * i-1, 2 * i - 2] + k[1, 0]
    K[
2 * i-1, 2 * i-1] = K[2 * i-1, 2 * i-1] + k[1, 1]
    K[
2 * i-1, 2 * j - 2] = K[2 * i-1, 2 * j - 2] + k[1, 2]
    K[
2 * i-1, 2 * j-1] = K[2 * i-1, 2 * j-1] + k[1, 3]
    K[
2 * j - 2, 2 * i - 2] = K[2 * j - 2, 2 * i - 2] + k[2, 0]
    K[
2 * j - 2, 2 * i-1] = K[2 * j - 2, 2 * i-1] + k[2, 1]
    K[
2 * j - 2, 2 * j - 2] = K[2 * j - 2, 2 * j - 2] + k[2, 2]
    K[
2 * j - 2, 2 * j-1] = K[2 * j - 2, 2 * j-1] + k[2, 3]
    K[
2 * j-1, 2 * i - 2] = K[2 * j-1, 2 * i - 2] + k[3, 0]
    K[
2 * j-1, 2 * i-1] = K[2 * j-1, 2 * i-1] + k[3, 1]
    K[
2 * j-1, 2 * j - 2] = K[2 * j-1, 2 * j - 2] + k[3, 2]
    K[
2 * j-1, 2 * j-1] = K[2 * j-1, 2 * j-1] + k[3, 3]
return (K)
K = fun2(K, k1,
1, 2)
K= fun2(K, k2,
1, 3)
K= fun2(K, k3,
1, 4)
print(K)
# 求节点位移
k=K[0:2, 0:2]
k=np.mat(k)
F=np.mat([
0,-1000])
u=k.I*F.T
print(u)
# 求单元应力
C1=np.mat([-C1,-S1,C1,S1])
C2=np.mat([-C2,-S2,C2,S2])
u = np.row_stack((u, [
0],[0]))
stress1=E/L1*C1*u
stress2=E/L2*C2*u
print(stress1)
print(stress2)
计算结果如下图
第二篇:2d杆单元的图8
三、Abaqus求解
步骤1:离散化
第二篇:2d杆单元的图9
步骤2:创建单元、施加边界条件
第二篇:2d杆单元的图10
步骤3:求解,后处理
第二篇:2d杆单元的图11
结果:
1.整体刚度矩阵如下图:
第二篇:2d杆单元的图12
2.节点位移u1=-0.0952mm,v1=-0.1906mm,如下:
第二篇:2d杆单元的图13
第二篇:2d杆单元的图14
3.单元1的σ1=2.8Mpa,σ2=-2Mpa。,如下图:
第二篇:2d杆单元的图15
结论:
不难发现,手工计算、python计算、Abaqus计算结果完全一致。
有什么问题欢迎与我交流微信联系
第二篇:2d杆单元的图16
点赞 1 评论 收藏 5
