数控G代码和M代码表!
2021年6月2日 14:41G code G代码 |
Group 组号 |
Meaning 含义 |
G00 |
01* |
Rapid motion (快速运动) |
G01 |
01 |
Linear interpolation motion (直线插补运动) |
G02 |
01 |
CW interpolation motion (顺圆插补运动) |
G03 |
01 |
CCW interpolation motion (逆圆插补运动) |
G04 |
00 |
Dwell (暂停) |
G09 |
00 |
Exact stop (准确停止) |
G10 |
00 |
Programmable data input (可编程数据输入) |
G11 |
00 |
Programmable data input cancel (可编程数据输入取消) |
G15 |
17* |
Polar coordinate cancel (极坐标编程取消) |
G16 |
17 |
Polar coordinate (极坐标编程) |
G17 |
02* |
XY plane selection (XY平面选择) |
G18 |
02 |
ZX plane selection (ZX平面选择) |
G19 |
02 |
YZ plane selection (YZ平面选择) |
G20 |
06* |
Select inches (选择英制) |
G21 |
06 |
Select metric (选择公制) |
G28 |
00 |
Return to reference point (返回参考点) |
G29 |
00 |
Return from reference point (从参考点返回) |
G30 |
00 |
Return to 2nd ,3rd,4th reference point (返回第2、3、4参考点) |
G31 |
00 |
Feed until skip (跳转) |
G33 |
01 |
Threading (螺纹切削) |
G40 |
07* |
Cutter compensation cancel (取消刀具补偿) |
G41 |
07 |
Cutter compensation left (刀具左补偿) |
G42 |
07 |
Cutter compensation right (刀具右补偿) |
G43 |
08 |
Tool length compensation + (刀具长度补偿+) |
G44 |
08 |
Tool length compensation - (刀具长度补偿-) |
G49 |
08* |
G43/G44 cancel (取消G43/G44) |
G50 |
11* |
G51 cancel (取消G51) |
G51 |
11 |
Scaling (比例缩放) |
G52 |
00 |
Set local coordinate system (设定局部坐标系) |
G53 |
00 |
Non-modal machine coordinate selection (非模态机床坐标系选择) |
G54 |
14* |
Select work coordinate system 1 (设定工件坐标系1) |
G55 |
14 |
Select work coordinate system 2 (设定工件坐标系2) |
G56 |
14 |
Select work coordinate system 3 (设定工件坐标系3) |
G57 |
14 |
Select work coordinate system 4 (设定工件坐标系4) |
G58 |
14 |
Select work coordinate system 5 (设定工件坐标系5) |
G59 |
14 |
Select work coordinate system 6 (设定工件坐标系6) |
G60 |
00 |
Unidirectional positioning (单一方向定位) |
G61 |
15 |
Exact stop modal (模态准确停止) |
G64 |
15* |
G61 cancel (取消G61) |
G65 |
00 |
Macro call (调用宏程序) |
G68 |
16 |
Rotation (旋转) |
G69 |
16* |
G68 cancel (取消G68) |
G73 |
09 |
Highspeed peck drilling cycle (高速深孔钻循环) |
G74 |
09 |
Left-handed tapping cycle (左旋攻丝循环) |
G76 |
09 |
Fine boring canned cycle (精镗循环) |
G80 |
09* |
Canned cycle cancel (取消固定循环) |
G81 |
09 |
Drilling cycle (钻孔循环) |
G82 |
09 |
Spot drilling cycle (钻孔循环,孔底暂停) |
G83 |
09 |
Normal peck drilling cycle (普通深孔钻循环) |
G84 |
09 |
Tapping cycle (攻丝循环) |
G85 |
09 |
Boring cycle (镗孔循环) |
G86 |
09 |
Boring cycle with spindle stop (镗/铰孔循环,孔底主轴停止) |
G87 |
09 |
Back boring cycle (背镗循环) |
G88 |
09 |
Boring cycle (镗孔循环,孔底暂停后,主轴停) |
G89 |
09 |
Boring and dwell cycle (镗孔循环,孔底暂停,主轴不停) |
G90 |
03* |
Absolute (绝对编程方式) |
G91 |
03 |
Incremental (增量编程方式) |
G92 |
00 |
Set work coordinates (设定工件坐标系) |
G94 |
05* |
Feed per minute (每分进给) |
G95 |
05 |
Feed per revolution (每转进给) |
G96 |
13 |
Constant surface speed (恒线速度切削) |
G97 |
13* |
Constant surface speed cancel (恒线速度切削取消) |
G98 |
10* |
Initial point return (返回初始点平面) |
G99 |
10 |
R plane return (返回R点平面) |
G code G代码 |
Group 组号 |
Meaning 含义 |
G12.1 |
21* |
Polar coordinate interpolation cancel (极坐标取消) |
G13.1 |
21 |
Polar coordinate interpolation (极坐标) |
G70 |
00 |
Finishing cycle (精车循环) |
G71 |
00 |
Stock removal in turning (外圆粗车循环) |
G72 |
00 |
Stock removal in facing (端面粗车循环) |
G73 |
00 |
Pattern repeating cycle (封闭切削循环) |
G74 |
00 |
End face peck drilling cycle (端面啄式钻孔循环) |
G75 |
00 |
Longitudinal cut off cycle (切槽复合循环) |
G76 |
00 |
Multiple-thread cutting cycle (复合螺纹切削循环) |
G83 |
10 |
Cycle for face drilling (端面钻孔循环) |
G84 |
10 |
Cycle for face tapping (端面攻丝循环) |
G85 |
10 |
Cycle for face boring (端面镗孔循环) |
G87 |
10 |
Cycle for side drilling (侧面钻孔循环) |
G88 |
10 |
Cycle for side tapping (侧面攻丝循环) |
G89 |
10 |
Cycle for side boring (侧面镗孔循环) |
G98 |
05* |
G99 |
05 |
List of M codes
M code M代码 |
Meaning 含义 |
M00 |
Stop program (程序停止) |
M01 |
Optional program stop (程序选择停止) |
M02 |
Program end (程序结束) |
M03 |
Spindle forward (主轴正转) |
M04 |
Spindle reverse (主轴反转) |
M05 |
Spindle stop (主轴停转) |
M06 |
Tool change (自动换刀) |
M07 |
Coolant ON (Mist) (冷却液开启(雾状)) |
M08 |
Coolant ON (Flood) (冷却液开启(水状)) |
M09 |
Coolant OFF (冷却液关闭) |
M19 |
Orient spindle (主轴定向) |
M30 |
Program end and rewind (程序结束并反绕) |
M31 |
Chip conveyor forward (排屑器正转) |
M32 |
Chip conveyor reverse (排屑器反转) |
M33 |
Chip conveyor stop (排屑器停转) |
M34 |
Increment coolant spigot position (冷却液喷嘴位置上升) |
M35 |
Decrement coolant spigot position (冷却液喷嘴位置下降) |
M36 |
Pallet rotate (托盘回转) |
M39 |
Rotate tool turret (刀具转塔架回转) |
M41 |
Low gear shift (切换低挡齿轮) |
M42 |
High gear shift (切换高挡齿轮) |
M50 |
Execute pallet change (执行托盘交换) |
M82 |
Tool unclamp (刀具松开) |
M86 |
Tool clamp (刀具夹紧) |
M88 |
Through the spindle coolant ON (主轴中心孔冷却开启) |
M89 |
Through the spindle coolant OFF (主轴中心孔冷却关闭) |
M95 |
Sleep mode (睡眠模式) |
M96 |
Jump if no input (无输入则跳转) |
M97 |
Local subprogram call (局部子程序调用) |
M98 |
Subprogram call (子程序调用) |
M99 |
Subprogram return or loop (子程序返回或循环执行) |
