LS-DYNA错误求大佬们解答!!!!
Beginning of keyword reader 05/10/22 12:18:29
Memory required to process keyword : 19091970
*** Warning 20282 (STR+282)
warpage angle of element ID= 2366 is computed as 1.6715E+02 degrees.
warpage angle of element ID= 2373 is computed as 1.2494E+02 degrees.
*** Warning 21129 (STR+1129)
shell element, ID 2373 violates heuristic shape criterion
area/(longest diagonal)/(longest diagonal) equals: 1.6488E-03
which may be too small (< 0.1) to permit a stable calculation.
*** Warning 30100 (INI+100)
element ID 136741 is a very badly
shaped element-possibly unstable.
Possible reason for error termination.
warpage angle of element ID= 136745 is computed as 2.8588E+01 degrees.
*** Warning 20289 (STR+289)
Number of elements exceed warpage angle = 3
min warpage angle = 2.8588E+01
max warpage angle = 1.6715E+02
input of data is completed
*** Warning 30104 (INI+104)
all contact segments are reversed.
interface # 1 slave side
*** Error 30099 (INI+99)
element ID 136741 has a zero normal vector.
initial kinetic energy = NaN
*** Warning 30131 (INI+131)
total number of massless nodes = 14
The LS-DYNA time step size should not exceed 3.112E-04
to avoid contact instabilities. If the step size is
bigger then scale the penalty of the offending surface.
*** Error 30006 (INI+6)
initialization completed with 2 or more fatal errors
please check messag file
Memory required to begin solution : 20M
Additional dynamically allocated memory: 73M
Total: 92M
initialization completed with 3 or more fatal errors
E r r o r t e r m i n a t i o n 05/10/22 12:18:56
Memory required to complete solution : 20M
Total: 92M
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Keyword Processing ... 8.0000E+00 28.57 8.5370E+00 30.24
KW Reading ......... 5.0000E+00 17.86 4.5720E+00 16.19
KW Writing ......... 1.0000E+00 3.57 1.2670E+00 4.49
Initialization ....... 2.0000E+01 71.43 1.9695E+01 69.76
Init Proc Phase 1 .. 2.0000E+00 7.14 1.7800E+00 6.30
Init Proc Phase 2 .. 1.8000E+01 64.29 1.7741E+01 62.84
T o t a l s 2.8000E+01 100.00 2.8232E+01 100.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 28 seconds ( 0 hours 0 minutes 28 seconds)
CPU time per zone cycle = 0.000 picoseconds
Clock time per zone cycle= 0.000 picoseconds
Number of CPU's 4
NLQ used/max 136/ 136
Start time 05/10/2022 12:18:29
End time 05/10/2022 12:18:57
Elapsed time 28 seconds for 0 cycles using 4 SMP threads
( 0 hour 0 minute 28 seconds)
E r r o r t e r m i n a t i o n 05/10/22 12:18:57
