abaqus中做的组合结构施加位移荷载的模型,总是出现错误怎么解决
status文件如下
PREPROCESSOR WARNING MESSAGES
***WARNING: There are 3 warning messages in the data (.dat) file.  Please
            check the data file for possible errors in the input file.
***WARNING: In step 1, portions of main surfaces in the general contact domain
            have been tied together.  Joining disconnected surfaces with *TIE
            does not alter the surface connectivity and results in a seam in
            the contact surface.  The nodes along the tied surface perimeters
            have been added to the node set named  "WarnNodePerimTieSeam".
DOMAIN DECOMPOSITION INFORMATION
DOMAIN 1 HAS 20427 ELEMENTS AND 236230 NODES with WEIGHT 50.000
DOMAIN 2 HAS 20374 ELEMENTS AND 35041 NODES with WEIGHT 50.000
 MODEL INFORMATION (IN GLOBAL X-Y COORDINATES)
 Total mass (unscaled) in model = 2114.5
   Center of mass of model (based on unscaled mass) = (-1.044988E+00,-4.382002E-02, 4.501347E-01)
 Moments of Inertia :
                 About Center of Mass              About Origin
      I(XX)          7.368090E+02                  1.169308E+03
      I(YY)          4.353721E+03                  7.091177E+03
      I(ZZ)          3.800590E+03                  6.113667E+03
      I(XY)         -1.301940E-02                 -9.683819E+01
      I(YZ)          1.339122E-04                  4.170814E+01
      I(ZX)          1.588352E+01                  1.010506E+03
 STABLE TIME INCREMENT INFORMATION
The stable time increment estimate for each element is based on
  linearization about the initial state. The stable time increment estimates
  do not account for mass scaling.
Initial time increment = 1.69246E-07
Statistics for all elements:
      Mean = 1.47325E-06
      Standard deviation = 8.71975E-07
   Most critical elements:
    Element number   Rank    Time increment   Increment ratio
    (Instance name)
       14533          1       1.692461E-07      1.000000E+00
    shear plate-1
       11723          2       1.692461E-07      1.000000E+00
    shear plate-1
       13128          3       1.692461E-07      9.999999E-01
    shear plate-1
       13255          4       2.052185E-07      8.247115E-01
    shear plate-1
       14660          5       2.052185E-07      8.247115E-01
    shear plate-1
       11850          6       2.052185E-07      8.247115E-01
    shear plate-1
        2979          7       2.217974E-07      7.630661E-01
    shear plate-1
        1765          8       2.217974E-07      7.630661E-01
    shear plate-1
         551          9       2.217974E-07      7.630661E-01
    shear plate-1
       14652         10       2.496846E-07      6.778395E-01
    shear plate-1
 Instance name for the most critical element will be printed if the critical
  element changes or at the beginning of a new page.
