Abaqus python脚本开发 第三章 各类指令的方法对象变量 (3)
3.3.1 DatumPlaneByOffset(...)
Abaqus python脚本开发 第三章 各类指令的方法对象变量 (3)的图1
This method creates a Feature object and a DatumPlane object offset by a specified distance from an existing plane.
Path
mdb.models[name].rootAssembly.DatumPlaneByOffset
mdb.models[name].parts[name].DatumPlaneByOffset
Required arguments
plane
A planar Face, an ElementFace, or a Datum object representing a datum plane.
flip
A SymbolicConstant specifying whether the normal should be flipped. Possible values are SIDE1 and SIDE2.
offset
A Float specifying the offset from the plane.
Optional arguments
None.
Return value
A Feature object.
Exceptions
AbaqusException.
def Datum_Plane_by_Offset(mdbname,My_plane,My_distance):
    a = mdb.models[mdbname].rootAssembly
    dp=a.DatumPlaneByOffset(plane=My_plane,flip=SIDE1,offset=My_distance)
    id_plane=dp.id
    return id_plane
3.2.2 DatumPlaneByTwoPoint(...)
Abaqus python脚本开发 第三章 各类指令的方法对象变量 (3)的图2
This method creates a Feature object and a DatumPlane object midway between two points and normal to the line connecting the points.
Path
mdb.models[name].rootAssembly.DatumPlaneByTwoPoint
mdb.models[name].parts[name].DatumPlaneByTwoPoint
Required arguments
point1
A Vertex, an InterestingPoint, a MeshNode, or a Datum object representing a datum point.
point2
Optional arguments
None.
Return value
A Feature object.
Exceptions
AbaqusException.
Script:
def Datumplane_by_Twopoints(mdbname,My_instance,My_vertices_id1,My_vertices_id2):
    v1 = a.instances[My_instance].vertices
    dp1=a.DatumPlaneByTwoPoint(point1=v1[My_vertices_id1], point2=v1[My_vertices_id2])
    id_plane=dp1.id
    return id_plane
3.2.3 DatumPlaneByThreePoints(...)
Abaqus python脚本开发 第三章 各类指令的方法对象变量 (3)的图3
This method creates a Feature object and a DatumPlane object defined by passing through three points.
Path
mdb.models[name].rootAssembly.DatumPlaneByThreePoints
mdb.models[name].parts[name].DatumPlaneByThreePoints
Required arguments
point1
point2
point3
Optional arguments
None.
Return value
A Feature object.
Exceptions
AbaqusException.
Script:
def Datumplane_by_Threepoints(mdbname,My_point1,My_point2,My_point3):
    a=mdb.models[mdbname].rootAssembly
    dp=a.DatumPlaneByThreePoints(point1=My_point1,point2=My_point2,point3=My_point3)
    id_plane=dp.id
    return id_plane
3.2.4 DatumPlaneByLinePoint(...)
Abaqus python脚本开发 第三章 各类指令的方法对象变量 (3)的图4
This method creates a Feature object and a DatumPlane object that pass through the specified line and through the specified point that does not lie on the line.
Path
mdb.models[name].rootAssembly.DatumPlaneByLinePoint
mdb.models[name].parts[name].DatumPlaneByLinePoint
Required arguments
line
A straight Edge, an ElementEdge, or a Datum object representing a datum axis.
point
Optional arguments
None.
Return value
A Feature object.
Exceptions
AbaqusException.
Script:
欢迎收藏转发,感谢!
Abaqus Python脚本开发持续更新中
微信公众号:山石结构
Bilibili:happyleo7
以下内容为付费内容,请购买后观看
Datumplane_by_Twopoints,DatumPlaneByThreePoints,DatumPlaneByLinePoint和 PartitionFaceByDatumPlane部分的代码
