Cadence Fidelity™ CFD 应该是 Numecan / OMNIS 改的!
看了官方的宣传资料,居然说几年前就有了,但是Cadence 才刚收购NUMECA和pointwise。而根据其官方油管宣传视频可见软件标识还是OMNIS。
Omnis/Hexpress – Surface to volume meshing approach
Omnis/Hexpress extends its unstructured mesh generation tool set with the surface-to-volume module.
The surface-to-volume module allows generating 3D grids with high-quality surface meshes, aligned with the geometry and with smooth and thickness-controlled viscous layers when the geometry is clean and conformal.
 Cadence Fidelity™ CFD 应该是 Numecan / OMNIS 改的!的图1
Omnis/Autogrid - Meridional effects with autoblocking (beta)
Omnis/AutoGrid can now generate multi-block structured meshes of axisymmetric meridional effects (e.g. seal leakage, bleed or cavities) connected to the channel of the turbomachinery configuration.
 Cadence Fidelity™ CFD 应该是 Numecan / OMNIS 改的!的图2
Omnis/Turbo – Coarse grid simulation
The Omnis/Turbo simulation can run on a coarser grid level with the same mesh and simulation setup. This feature allows to quickly assess the correct setup of the simulation and preview its results before a final accurate run on the finest grid level.
 Cadence Fidelity™ CFD 应该是 Numecan / OMNIS 改的!的图3
Omnis/Open (DBS and PBS) – Surface-to-surface radiation
The surface-to-surface (S2S) radiation model has been introduced in the Omnis/Open density-based and coupled pressure-based solvers to account for the radiation exchange in an enclosure of grey-diffuse surfaces.
 Cadence Fidelity™ CFD 应该是 Numecan / OMNIS 改的!的图4
Omnis/Oofelie – Advanced thermomechanical analysis for turbomachinery
Our commitment to providing more advanced solutions for turbomachinery designers continues with Omnis/Oofelie. The results of static runs can be used for calculating natural frequencies and mode shapes of mechanical parts. Other important new features include also the computation of complex mode shapes due to the presence of Coriolis effects and wet mode shapes, for machines with a high-density operating fluid.
 Cadence Fidelity™ CFD 应该是 Numecan / OMNIS 改的!的图5
Omnis/Mpacts – Particles motion and interaction (beta)
The new Omnis/Mpacts solver allows the simulation of particle collisions for a variety of industrial applications such as conveyor belts, hoppers and mixers.
Omnis/Mpacts combines the power of the advanced Discrete Element Method (DEM) solver Mpacts with the user-friendly Omnis interface and all its capabilities from the pre-processing to co/post-processing in one workflow.
 Cadence Fidelity™ CFD 应该是 Numecan / OMNIS 改的!的图6
Omnis/Post – Display streamlines
Users can now display streamlines to trace the flow velocity, from a point, line, plane, or sphere with interactive controls in Omnis/Post.
 Cadence Fidelity™ CFD 应该是 Numecan / OMNIS 改的!的图7
