六自由度机械臂五次多项式轨迹规划(Fivejtraj_Function自编写函数)
clear,clc,close all
format compact
robotModel=4;DH_Param;JointNum=length(DH);
ROCR6v2 关节2、3偏置
qlim=deg2rad([-179,179;-146,146;-146,146;-179,179;-179,179;-179,179]);
for i=1:JointNum
   L(i)=RevoluteMDH('d',DH(i,3),'a',DH(i,2),'alpha',deg2rad(DH(i,1)), ...
               'offset',deg2rad(DH(i,4)),'qlim',qlim(i,:));
end
robot=SerialLink(L,'name','robot');
robot.display();
robot =
robot:: 6 axis, RRRRRR, modDH, fastRNE
| j |     theta |         d |         a |     alpha |    offset |
|  1|         q1|     0.1215|          0|          0|          0|
|  2|         q2|     0.1225|          0|     1.5708|    -1.5708|
|  3|         q3|     -0.102|       -0.3|          0|          0|
|  4|         q4|       0.09|     -0.276|          0|    -1.5708|
|  5|         q5|       0.09|          0|     1.5708|          0|
|  6|         q6|      0.082|          0|    -1.5708|          0|
% 设置约束条件
Theta=[40,-30,-30,30,-15,20;
      0,15,0,10,20,50;
      -40,30,30,-20,30,30];
Velocity=[0,0,0,0,0,0;40,40,20,30,20,10;0,0,0,0,0,0];
Accle=[0,0,0,0,0,0;0,0,0,0,0,0;0,0,0,0,0,0];
[m,n]=size(Theta);
% 五次多项式轨迹规划,定义插补次数n,根据驱动器支持的最大插补次数设定
Time=[0,0,0,0,0,0;5,5,5,5,5,5;10,10,10,10,10,10];
StopTime=Time(3,1);
FixedStep=0.2;
SimpleNum=0:FixedStep:StopTime;Cunt=length(SimpleNum);
for i=1:n
   %% 求每个关节角的五次多项式插补轨迹点
   [q(:,i),qd(:,i),qdd(:,i)] = Fivejtraj_Function(Theta(:,i),Time(:,i), ...
                               Velocity(:,i),Accle(:,i),FixedStep);
end
qT=q';vT=qd';aT=qdd';t=2000;
%% 求正解
T=robot.fkine(deg2rad(q));        %求正解,得到每次对应的空间位姿矩阵
JTA=transl(T);                  %空间位姿矩阵转化为位置矩阵
rpy=tr2rpy(T,'xyz');            % T中提取姿态(rpy)
% times=n*0.256*4; %ms
%% 绘制末端位置
W=[-700,+700,-700,+700,0,+1000]*0.001;
% 求约束角度的正解,获取末端位姿
T1=robot.fkine(deg2rad(Theta(1,:)));
T2=robot.fkine(deg2rad(Theta(2,:)));
T3=robot.fkine(deg2rad(Theta(3,:)));
% 动态仿真
figure('Color',[1,1,1],'Position',[485,180,386,310],'Visible','on');
plot3(JTA(1:end,1), JTA(1:end,2), JTA(1:end,3),'b','LineWidth',1.5);
axis(W);   %设置坐标轴范围
hold on;grid on;
plot3(T1.t(1),T1.t(2),T1.t(3),'o','color','r','LineWidth',2);%#7E2F8E
plot3(T2.t(1),T2.t(2),T2.t(3),'o','color','r','LineWidth',2);
plot3(T3.t(1),T3.t(2),T3.t(3),'o','color','r','LineWidth',2);
% robot.plot(q*rad2deg,'tilesize',0.150,'workspace',W,'trail',{'r','LineWidth',3});
robot.model3d = 'ROCR6/MDH_stl';
robot.plot3d(deg2rad(q),'workspace',W,'movie','JointSpace.gif', ...
           'view',[24 30],'trail',{'r','LineWidth',3.5}) %显示三维动画
Animate: saving video --> JointSpace.gif with profile 'GIF'
Loading STL models from ARTE Robotics Toolbox for Education  by Arturo Gil (http://arvc.umh.es/arte).......
light('Position', [1 0.5 1]);
六自由度机械臂五次多项式轨迹规划(Fivejtraj_Function自编写函数)的图1
%% 绘制曲线图
figure('Color',[1,1,1],'Position',[485,180,536,325]);
for i=1:n
plot(SimpleNum,qT(i,1:Cunt),'LineWidth',2);hold on;
end
string='关节角度(deg)';
xlabel('t(s)'),ylabel(string,'Interpreter','tex','FontSize',10);grid on;
legend1 = legend('joint1 ','joint2','joint3','joint4','joint5','joint6');
set(legend1,...
   'Position',[0.06 0.94 0.89 0.06],...
   'Orientation','horizontal');
六自由度机械臂五次多项式轨迹规划(Fivejtraj_Function自编写函数)的图2
for i=1:n
plot(SimpleNum,vT(i,1:Cunt),'LineWidth',2);hold on;
end
string='关节角速度(deg/s)';
六自由度机械臂五次多项式轨迹规划(Fivejtraj_Function自编写函数)的图3
for i=1:n
plot(SimpleNum,aT(i,1:Cunt),'LineWidth',2);hold on;
end
string='关节角加速度(deg/s^2)';
六自由度机械臂五次多项式轨迹规划(Fivejtraj_Function自编写函数)的图4
源文件下载链接
需要技术服务联系qq2386317960
以下内容为付费内容,请购买后观看
六自由度机械臂五次 三次多项式轨迹规划(自编多项式写函数)
