重启动CAE操作:
重启动CAE操作:
Output - restart requests
复制模型:
*Heading
** Job name: Job-2 Model name: Model-2
** Generated by: Abaqus/CAE 2020
*Preprint, echo=NO, model=NO, history=NO, contact=NO
*Restart, read, step=1
*Amplitude, name=Amp-1
0., 1,. 1.(时间长度), 0.5 (幅值)
** STEP: Step-2
*Step, name=Step-2, nlgeom=YES
*Dynamic, Explicit
, 1. (时间长度)
*Bulk Viscosity
0.06, 1.2
** LOADS
** Name: Load-1 Type: Concentrated force
*Cload, amplitude=Amp-1
RP, 1, 100. (幅值倍数)
** OUTPUT REQUESTS
*Restart, write, number interval=150, time marks=NO
** FIELD OUTPUT: F-Output-1
*Output, field, number interval=300
*Node Output
COORD, U
** FIELD OUTPUT: COOR
*Node Output, nset=RP
COORD,
** HISTORY OUTPUT: H-Output-1
*Output, history, time interval=0.00333333
*Element Output, elset=CABLE
CTF1,
*End Step
*Heading
** Job name: Job-3
*Restart, read, step=2
*Amplitude, name=Amp-2
0., 1., 1., 0.5
** STEP: Step-3
*Step, name=Step-3, nlgeom=YES
*Dynamic, Explicit
, 1.
*Bulk Viscosity
0.06, 1.2
** LOADS
*Cload, amplitude=Amp-2
RP, 1, 100.
** OUTPUT REQUESTS
*Node Output
COORD, U
COORD,
CTF1,
*End Step
命令行提交过程:在开始界面输入 ABAQUS COMMAND打开DOS界面,切换路径到当前文件夹下—并执行重启动操作---“ABAQUS job=Job-3 oldjob=Job-2” (例:根据第二次仿真结果进行第三次仿真)
path=%path%;D:\SIMULIA\Abaqus\Commands
G:
CD G:\CABLE_CON\TEXT1
得到 Job-3.odb 文件
合并两个odb文件,并将结果保留在original中:
ABAQUS restartjoin originalodb=original.odb restartodb=restart.odb
ABAQUS restartjoin originalodb=original.odb restartodb=restart.odb history copyoriginal (保留历史数据, copyoriginal 原本的ODB会保留一份)
