huang隐式程序修改为显式及计算案例
黄永刚原始晶体塑性具有良好的收敛性,以及高效的计算效率,在一般变形下无需修改,即可直接使用。然而一些特殊的工况,如切削,轧制,冲压等隐式存在收敛性问题。因此通常使用显示程序进行计算。但从头完成显式晶体塑性构造对于一般学者显然难度过高,一个简单的想法就是直接将现成的黄永刚隐式程序改成显式。abaqus里这是可以实现的。其基本的步骤是:
1,加入vumat接口程序(见附录abaqus官网有)
2,对nblock进行循环,计算应力和状态变量
3,更新应力与状态变量,重复计算直到增量结束。
值得注意的是,umat与vumat程序里面剪应力分量定义顺序与应力不同
umat:12,13,23(工程剪应变)
vumat:12,23,13(2*工程剪应变)
同时采用该方法计算时计算效率显著高于完全显式,并允许较大的时间增量。为评估模型计算效率,采用1000个晶粒80000个单元的二维模型进行20%的压缩模拟。耗时3小时,计算结果与隐式结果类似。模型结果如下:
附录
subroutine vumat(
C Read only (unmodifiable)variables -
1 nblock, ndir, nshr, nstatev, nfieldv, nprops, jInfoArray,
2 stepTime, totalTime, dtArray, cmname, coordMp, charLength,
3 props, density, strainInc, relSpinInc,
4 tempOld, stretchOld, defgradOld, fieldOld,
5 stressOld, stateOld, enerInternOld, enerInelasOld,
6 tempNew, stretchNew, defgradNew, fieldNew,
C Write only (modifiable) variables -
7 stressNew, stateNew, enerInternNew, enerInelasNew )
C
include 'vaba_param.inc'
parameter (i_info_AnnealFlag = 1,
* i_info_Intpt = 2, ! Integration station number
* i_info_layer = 3, ! Layer number
* i_info_kspt = 4, ! Section point number in current layer
* i_info_effModDefn = 5, ! =1 if Bulk/ShearMod need to be defined
* i_info_ElemNumStartLoc = 6) ! Start loc of user element number
C
dimension props(nprops), density(nblock), coordMp(nblock,*),
1 charLength(nblock), dtArray(2*(nblock)+1), strainInc(nblock,ndir+nshr),
2 relSpinInc(nblock,nshr), tempOld(nblock),
3 stretchOld(nblock,ndir+nshr),
4 defgradOld(nblock,ndir+nshr+nshr),
5 fieldOld(nblock,nfieldv), stressOld(nblock,ndir+nshr),
6 stateOld(nblock,nstatev), enerInternOld(nblock),
7 enerInelasOld(nblock), tempNew(nblock),
8 stretchNew(nblock,ndir+nshr),
8 defgradNew(nblock,ndir+nshr+nshr),
9 fieldNew(nblock,nfieldv),
1 stressNew(nblock,ndir+nshr), stateNew(nblock,nstatev),
2 enerInternNew(nblock), enerInelasNew(nblock), jInfoArray(*)
C
character*80 cmname
C
pointer (ptrjElemNum, jElemNum)
dimension jElemNum(nblock)
C
lAnneal = jInfoArray(i_info_AnnealFlag)
iLayer = jInfoArray(i_info_layer)
kspt = jInfoArray(i_info_kspt)
intPt = jInfoArray(i_info_Intpt)
iUpdateEffMod = jInfoArray(i_info_effModDefn)
iElemNumStartLoc = jInfoArray(i_info_ElemNumStartLoc)
ptrjElemNum = loc(jInfoArray(iElemNumStartLoc))
do 100 km = 1,nblock
user coding
100 continue
returnend
2,
点赞 4 评论 1 收藏 10
