流固双向耦合报错问题
Update failed for the Solution component in System Coupling.  The coupled update for system Fluid Flow (Fluent) threw an exception. The FLUENT application failed to initialize.
(DP 0) An unknown error occurred during solution.  Check the Solver Output on the Solution Information object for possible causes.
(DP 0) A solver failure occurred during the run in the Fluid Flow (Fluent) system Please do not save the project if you would like to recover to the last saved state.
(1条)
后续怎么解决呢大神,我也遇到了同样问题
评论 1 点赞
回复
这个是电脑的问题,带不动而已,注意一下动网格那里,运动面设置为耦合,其余要设置为变形
评论 点赞
点赞 评论 2 收藏
