FORTRAN 延时函数
在子程序中需要用到一些延时功能,
在vs编译器中直接调用 *call sleep(5),可以实现5s的延时
在子程序中直接 *call sleep(5),会出现‘’Problem during linking - Abaqus/Standard User Subroutines. This error may be due to a mismatch in the Abaqus user subroutine arguments. These arguments sometimes change from release to release, so user subroutines used with a previous release of Abaqus may need to be adjusted.‘’,veryfication subroutine 是pass, 浪费了我好多时间,修改加上一句 *USE DFPORT,程序可以正确通过
点赞 评论 收藏
