Moldex3D AWS-Connect之AWS ParallelCluster-1
三.AWS ParallelCluster
An open-source cluster management tool to deploy and manage High Performance Computing (HPC) clusters on AWS.
Uses a simple text file to model and provision all the resources needed for your HPC applications in an automated and secure manner.
Supports multiple instance types and job submission queues, and job schedulers like AWS Batch and Slurm.
Reference
https://aws.amazon.com/tw/hpc/parallelcluster/
1. Architecture of cluster deployed by AWS ParallelCluster + Several manual steps
Moldex3D AWS-Connect之AWS ParallelCluster-1的图1
2. Before installing AWS ParallelCluster
A Linux environment is required.
Current latest version of AWS ParallelCluster is 3.3.0
-We have tested Linux node on-premises with CentOS 7 and RHEL 8, and both of them can only get latest AWS ParallelCluster as version 3.1.4.
We have installed AWS ParallelCluster on EC2 instance with Amazon Linux 2 as the operating system. In this environment the latest AWS ParallelCluster installed is 3.3.0.
-This guide is based on AWS ParallelCluster 3.3.0, therefore use Amazon Linux 2 to install AWS ParallelCluster is strongly recommended.
(1)Create EC2 instance for installing AWS ParallelCluster (Create VPC)
Log in AWS Console --> Search VPC --> Create VPC
Moldex3D AWS-Connect之AWS ParallelCluster-1的图2
Set Name tag auto-generation as "amazonlinux"
Number of Availability Zones (AZs) set to 1. Number of private subnets set to 0. NAT gateways ($) set to None. VPC endpoints set to None. --> Press "Create VPC" button.
Moldex3D AWS-Connect之AWS ParallelCluster-1的图3
Moldex3D AWS-Connect之AWS ParallelCluster-1的图4
(2) Create EC2 instance for installing AWS ParallelCluster (Launch EC2 instance)
Go to service -> EC2 and press "Launch instance"
Moldex3D AWS-Connect之AWS ParallelCluster-1的图5
OS: select Amazon Linux 2 AMI
Moldex3D AWS-Connect之AWS ParallelCluster-1的图6
Instance type: select t2.micro
Moldex3D AWS-Connect之AWS ParallelCluster-1的图7
Key pair:
Press "Create new key pair"
Key pair name: awsparallelcluster
Key pair type: RSA
Private key file format: .pem
Press "Create key pair"
-Download awsparallelclsuter.pem
Moldex3D AWS-Connect之AWS ParallelCluster-1的图8
Please confirm
Key pair name
Network settings
-Network: amazonlinux-vpc
-Subnet: amazonlinux-subnet-public1-??
-Press "Edit" and change auto-assign public IP from "Disable" to "Enable"
Moldex3D AWS-Connect之AWS ParallelCluster-1的图9
Press "Launch instance"
Moldex3D AWS-Connect之AWS ParallelCluster-1的图10
(3) Create EC2 instance for installing AWS ParallelCluster (Connect to EC2 instance)
At AWS Console --> EC2 instance --> Find the public IP of the EC2 instance (name: amazonlinux)
Moldex3D AWS-Connect之AWS ParallelCluster-1的图11
Download and install PuTTY
https://www.putty.org/
Run "PuTTYgen"
Load "awsparallelcluster.pem"
Enter "key passphrase" and "confirm"
Press "Save private key"
Type filename as "awsparallelcluster.ppk"
Moldex3D AWS-Connect之AWS ParallelCluster-1的图12
Run PuTTY -> Type Host name of EC2 instance (amazonlinux)
Moldex3D AWS-Connect之AWS ParallelCluster-1的图13
Go to Connection->SSH->Auth -> Browse the ppk file created in last page
Moldex3D AWS-Connect之AWS ParallelCluster-1的图14
Press "Open"
Press "Accept"
Moldex3D AWS-Connect之AWS ParallelCluster-1的图15
Login as: please enter "ec2-user"
Enter passphrase for PPK key (awsparallelcluster.ppk)
Moldex3D AWS-Connect之AWS ParallelCluster-1的图16
Now you have created the Linux environment to install AWS ParallelCluster 3.3.0.
