ANSYS全部产品线
乘员保护/行人保护相关功能
· *LOAD_PYRO_ACTUATOR/*DATABASE_PYRO
· Calculates nodal/segment forces from a pyrotechnic piston actuator without the need to model the chamber/piston
· Input: nodes/segments, mass flow curve, chamber cross section area, etc
· Pressure tube sensor is used to deteck pedestrain collision
· New solution method options
- MTD=0: Standard Galerkin (CG) for Acoustic
- MTD=1: Discontinuous Galerkin (DG) for Acoustic Equations(Less diffusive than CG)
- MTD=2: DG for Isothermal Euler Equations <推荐>(More accurate for large amplitudes
Handles shocks and rarefaction waves)
更精确的模拟行人保护头部碰撞中的玻璃裂纹形状,业内有客户正在应用
碰撞相关先进材料模型
失效应变\失稳应变的应力三轴度相关、非线性路径相关损伤累计、网格无关性
高精度的地模拟金属、塑料的材料失效,已被广泛应用于各大汽车企业
DMN-based Multiscale Simulation of Short-Fiber Composites
Machine Learning-based Multiscale Analysis of Composites (cont.)
先进碰撞相关仿真方法
· 可压溃梁Crushable beam in LS-DYNA
· A beam element to simulate the behavior of beam type structures
· input Force/moment vs. displacement/rotation along local r, s and t
· 可以非常方便的将整车结构约束为一整个刚体而使得相冲突的关键字失效,在满足特定条件后恢复。方便加快某些工况(如翻滚、自动驾驶)的车体碰撞前的姿态计算。
· *CONSTRAINED_NODAL_RIGID_BODY together with *DEFORMABLE_TO_RIGID allows users to rigidize a few parts during a specified period of time. However rigidizing the whole vehicle for pre-crash simulation could be challenging since it will conflict with existing rigid body or constraint definitions.
· *CONSTRAINE_NODAL_RIGID_BODY_MASTER detects all conflicts and turns off all of them until the master rigid body is turned off by *SENSOR_CONTROL.
车辆抗爆Mid-field Air Blast: Van Under Mine Blast (Lateral)
电池安全相关:整车分析级别的电池多物理场挤压解决方案
先进断裂模拟方法
整车碰撞对连接件处的钣金撕裂、焊核热影响区断裂精准考量
