Missile Datcom基础应用及二次开发
Missile Datcom 软件的全称为Missile Data Compendium,是由美国空军飞行力学实验室开发的一款气动力工程计算软件。弹道计算时需要获得弹体在不同马赫数、海拔、速度等条件下飞行时的气动力系数。
一般可以使用 数值算法 和 工程算法 两种方式
(1)数值算法:利用 Fluent、CFD++ 等软件进行一系列复杂的前处理、求解器设置及后处理才可以进行计算,缺点显而易见,既考验使用者 Fluent、CFD++ 等软件的使用能力,又对电脑cpu等硬件的性能设置了门槛,普通的台式和笔记本难以堪当此任。
(2)工程算法:利用经验数据、实验数据及数学公式对弹体的气动力系数进行求解,Missile Datcom 软件就是应用了此种方式,优点:对使用者极其友好,通过看使用说明手册即可快速上手进行求解计算,并且计算速度快、对电脑配置没有要求,普通的笔记本、台式就可以。
Missile Datcom输入文件格式:
DERIV RAD
DIM M
$FLTCON
 NALPHA = 11.0,
 ALPHA = -5.0,-4.0,-3.0,-2.0,-1.0,0.0,1.0,2.0,3.0,4.0,5.0,6.0,
 NMACH = 10.0,
 MACH = 0.650,0.700,0.750,0.800,0.850,0.930,1.100,1.500,2.000,2.500,
 ALT = 0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,0.00,
$END
$REFQ
 SREF = 0.011310,
 LREF = 0.120000,
 XCG = 0.422900,
 RHR = 400.000000,
$END
$AXIBOD
 NX = 31.0,
 X = 0.00000000,0.00382000,0.00938000,0.01400000,0.01846000,
     0.02434000,0.03189000,0.04020000,0.04587000,0.05175000,
     0.05454000,0.06392000,0.07687000,0.08947000,0.10753000,
     0.15606000,0.18021000,0.20110000,0.22328000,0.25164000,
     0.28746000,0.31408000,0.34530000,0.37658000,0.40578000,
     0.43903000,0.46965000,0.50304000,0.53643000,0.60281000,
     0.70490000,
 R = 0.00359000,0.00636000,0.00918000,0.01121000,
     0.01323000,0.01524000,0.01599000,0.01682000,0.01870000,
     0.02063000,0.02156000,0.02156000,0.02763000,0.03276000,
     0.03899000,0.05079000,0.05493000,0.05781000,0.05936000,
     0.05969000,0.05781000,0.05493000,0.05025000,0.04459000,
     0.03898000,0.03276000,0.02574000,0.02155000,0.01737000,
     0.01737000,0.01737000,
$FINSET1
 SECTYP = HEX,
 NPANEL = 8.,
 PHIF = 0.00,45.00,90.00,135.00,180.00,225.00,270.00,315.00,
 XLE = 0.640,
 SWEEP = 13.4,13.4,60.0,60.0,
 SSPAN = 0.017,0.030,0.036,0.049,
         0.054,
 CHORD = 0.065,0.067,0.065,0.044,
         0.026,
 STA = 0.0,0.0,0.0,0.0,
       0.0,
 ZUPPER = 0.003000,0.003000,0.003000,0.003000,
          0.003000,
 LFLATU = 0.065000,0.067000,0.065000,0.044000,
          0.026000,
$END
*SAVE
DAMP
SPIN
PART
*SOSE
NEXT CASE
实际运行时需要根据需要修改 for005.dat 文件,软件运行完成后,文件夹中出现许多文件,汇总的气动力系数结果文件为 for042.csv 中,使用者可对照使用手册将所需的气动力系数挑选出来。此外,如果想要查看 for005.dat 中建立好的模型,可使用 Tecplot 打开 for022.dat 文件即可看到模型的三维效果图。
本人针对Missile Datcom软件进行了二次开发,可以对计算后的气动力系数进行统计,形成固定格式文档,以便进行弹道计算使用。
实际效果如下图所示,使用中有问题可联系本人QQ解决。
Missile Datcom基础应用及二次开发的图2
该付费内容为:软件可执行文件
0人购买
