ABAQUS中隐式和显式的节点和单元的输出变量解析
The output variables listed below are available in Abaqus/Explicit.
Mechanical analysis–nodal quantities
CFORCE
Field: yes  History: no  .fil: no
Contact normal force (CNORMF) and frictional shear force (CSHEARF).
CDISP
Contact opening (COPEN) and accumulated tangential motions (CSLIP1, CSLIP2, and
CSLIPEQ) for general contact analyses.
CEDGEACTIVE
Status of contact edges for general contact analyses (active as primary, active as
secondary and deactive).
CFRICWORK
Contact frictional work for general contact analyses.
CNAREA
Contact nodal area for each node with active contact forces in general contact, based on
area contributions from adjacent surface facets projected to a plane perpendicular to the
current nodal contact normal force vector.
CORIENT
Surface tangent directions (CORIENT1 and CORIENT2) for general contact analyses.
CSLIPR
Instantaneous contact slip rates (CSLIPR1, CSLIPR2, and CSLIPRMAG) for general contact
analyses.
CSTATUS
Contact status for general contact analyses.
CSTRESS
Contact pressure (CPRESS) and magnitude of the frictional shear stress (CSHEARMAG) for
Contact pressure (CPRESS) and frictional shear stresses (CSHEAR1 and CSHEAR2) for
contact pair analyses.
CTANDIR
Instantaneous contact tangent directions (CTANDIR1 and CTANDIR2) for general contact
analyses.
CTHICK
Contact thickness for general contact analyses.
CSMAXSCRT
Maximum value of the maximum stress-based damage initiation criterion for cohesive
surfaces in general contact up to the current increment.
CSQUADSCRT
Maximum value of the quadratic stress-based damage initiation criterion for cohesive
CSMAXUCRT
Maximum value of the maximum separation-based damage initiation criterion for cohesive
CSQUADUCRT
Maximum value of the quadratic separation-based damage initiation criterion for cohesive
CSDMG
Damage variable for cohesive surfaces in general contact.
FSLIP
Length of contact slip path at secondary nodes during contact (FSLIPEQ) and in some
cases (see About contact pairs in Abaqus/Explicit) components of net contact slip in local
tangent directions (FSLIP1 and FSLIP2). These variables remain constant while a
secondary node is not in contact.
FSLIPR
Magnitude of contact slip rate at secondary nodes during contact (FSLIPR) and in some
cases (see About contact pairs in Abaqus/Explicit) components of contact slip rate in local
tangent directions (FSLIPR1 and FSLIPR2). These variables are set to zero while a
BONDSTAT
Field: no  History: yes  .fil: no
Spot weld bond status.
BONDLOAD
Spot weld bond load.
CFORCEC
Consistent contact normal force (CNORMFC) and frictional shear force (CSHEARFC) in
general contact with active C3D10 elements.
Crack bond failure quantities
DBT
Time when bond failure occurs.
DBS
All components of remaining stress in the failed bond.
DBSF
Fraction of stress that remains at bond failure.
BDSTAT
Bond state (the state is 1.0 if bonded, 0.0 if unbonded).
OPENBC
Relative displacement behind crack when fracture criterion is met.
CRSTS
All components of critical stress at failure.
ENRRT
All components of strain energy release rate.
EFENRRTR
Effective energy release rate ratio
Mechanical analysis–whole surface quantities
CFN
Total force due to contact pressure (CFNn, n = 1, 2, 3).
CFNM
Magnitude of total force due to contact pressure.
CFS
Total force due to frictional stress (CFSn, n = 1, 2, 3).
CFSM
Magnitude of total force due to frictional stress.
CFT
Total force due to contact pressure and frictional stress (CFTn, n = 1, 2, 3).
CFTM
Magnitude of total force due to contact pressure and frictional stress.
CMN
Total moment about the origin due to contact pressure (CMNn, n = 1, 2, 3).
CMNM
Magnitude of total moment about the origin due to contact pressure.
CMS
Total moment about the origin due to frictional stress (CMSn, n = 1, 2, 3).
CMSM
Magnitude of total moment about the origin due to frictional stress.
CMT
Total moment about the origin due to contact pressure and frictional stress (CMTn, n = 1,
2, 3).
CMTM
Magnitude of total moment about the origin due to contact pressure and frictional stress.
CAREA
Total area in contact.
XN
Center of the total force due to contact pressure (XNn, n = 1, 2, 3).
XS
Center of the total force due to frictional stress (XSn, n = 1, 2, 3).
XT
Center of the total force due to contact pressure and frictional stress (XTn, n = 1, 2, 3).
Fully coupled temperature-displacement analysis
HFL
Heat flux per unit area leaving the surface.
HFLA
HFL multiplied by the nodal area.
HTL
Time integrated HFL.
HTLA
HTL multiplied by the nodal area.
SFDR
Heat flux per unit area due to frictional dissipation.
SFDRA
SFDR multiplied by the nodal area.
SFDRT
Time integrated SFDR.
SFDRTA
SFDRT multiplied by the nodal area.
