S-ALE造波,无板造波,边界流速法
https://ftp.lstc.com/anonymous/outgoing/hao/sale/models/waterlanding/
这是网络上的一个速度边界的SALE造波方法,包含k文。
速度边界造波(应该也叫无板造波吧)
BOUNDARY_PRESCRIBED_MOTION_SET设置输入端和输出端x方向速度,以及输入端y方向速度,去模拟波浪。
但直接下载的k文件只能使用高版本lsrun进行仿真还需要开启双精度,还有就是他进行了流固耦合,可能是计算量比较大,我直接使用仿真的话结果是很不理想的
根据以上例子删除相关结构,只保留水后进行了仿真还算是可以,边界流速和波高的关系还有待商榷,一起探讨。
main.k
$# LS-DYNA Keyword file created by LS-PrePost(R) V4.9.16-04Aug2023
$# Created on Oct-17-2023 (10:34:01)
$$ HM_OUTPUT_DECK created 10:36:08 07-07-2017 by HyperMesh Version 13.0.0.119
$$ Ls-dyna Input Deck Generated by HyperMesh Version  : 13.0.0.119
$$ Generated using HyperMesh-Ls-dyna 971_R6.1 Template Version : 13.0
*KEYWORD
*TITLE
$#        title
LS-DYNA keyword deck by LS-PrePost
*CONTROL_ALE
$#     dct      nadv      meth      afac      bfac      cfac      dfac      efac
         0         0         1      -1.0       0.0       0.0       0.0       0.0
$#   start       end     aafac     vfact      prit       ebc      pref   nsidebc
       0.01.00000E20       1.01.00000E-6         0         0  101300.0         0
$#    ncpl      nbkt    imascl    checkr    beamin   mmgpref    pdifmx   dtmufac
         1        50         0       0.0
$# optimpp    ialedr    bndflx    minmas
         0         0         01.00000E-5
$-----------------------------------ALE-CARDS-----------------------------------
*CONTROL_MPP_DECOMPOSITION_DISTRIBUTE_ALE_ELEMENTS
*CONTROL_OUTPUT
$#   npopt    neecho    nrefup    iaccop     opifs    ipnint    ikedit    iflush
         0         0         0         0       0.0         0       100       100
$#   iprtf    ierode   tet10s8    msgmax    ipcurv      gmdt   ip1dblt      eocs
         0         0         2        50         0       0.0         0         0
$#   tolev    newleg    frfreq     minfo    solsig    msgflg    cdetol
         2         0         1         0         0         0      10.0
$# phschng    demden   icrfile   spc2bnd    penout    shlsig   hisnout    engout
         0         0
*CONTROL_TERMINATION
$#  endtim    endcyc     dtmin    endeng    endmas     nosol
       0.4         0       0.0       0.0       0.0
*CONTROL_TIMESTEP
$#  dtinit    tssfac      isdo    tslimt     dt2ms      lctm     erode     ms1st
       0.0       0.7         0       0.0       0.0         0         0         0
$#  dt2msf   dt2mslc     imscl    unused    unused     rmscl     emscl      ihdo
       0.0         0         0                           0.0
$--------------------------------BOUNDARY-CONDITIONS----------------------------
*BOUNDARY_NON_REFLECTING
$#    ssid        ad        as
         1       0.0       0.0
*BOUNDARY_PRESCRIBED_MOTION_SET
$----wave making (3) and flow-in(2)/flow-out(12)
$#    nsid       dof       vad      lcid        sf       vid     death     birth
         2         1         0         3       1.0         01.00000E28       0.0
        12         1         0         3       1.0         01.00000E28       0.0
         3         2         0         2       1.0         01.00000E28       0.0
*BOUNDARY_SPC_SET_ID
$#      id                                                               heading
         0cemian
$----no side flow-in/flow-out
$#    nsid       cid      dofx      dofy      dofz     dofrx     dofry     dofrz
        11         0         0         0         1         1         1         1
$#      id                                                               heading
         0down
$----bottom flow along x direction only
         4         0         0         1         1         1         1         1
*NODE
$#   nid               x               y               z      tc      rc
  886400            -6.0            -3.0             0.0       0       0
 2000000            -6.0             0.0             4.0       0       0
 2000001             6.0             0.0             0.0       0       0
*ALE_AMBIENT_HYDROSTATIC
$#  alesid     stype     vecid      grav     pbase   ramptlc
         2         2         1    9.8065  101300.0         0
$#     nid     mmgbl
    886400         1
   2000000         2
*ALE_MULTI-MATERIAL_GROUP
$#     sid    idtype
         1         1
         2         1
$-------------------------------------GRAVITY/LOADING---------------------------
*LOAD_BODY_Y
$#    lcid        sf    lciddr        xc        yc        zc       cid
         5  -9.80665         0       0.0       0.0       0.0         0
*PART
$#        title
air
$#     pid     secid       mid     eosid      hgid      grav    adpopt      tmid
         1         1         3         1         0         0         0         0
*SECTION_SOLID
$#   secid    elform       aet    unused    unused    unused    cohoff   gaskeit
         1        11
*MAT_NULL_TITLE
Air
$#     mid        ro        pc        mu     terod     cerod        ym        pr
         3      1.29     -10.0       0.0       0.0       0.0       0.0       0.0
*EOS_LINEAR_POLYNOMIAL_TITLE
Air
$#   eosid        c0        c1        c2        c3        c4        c5        c6
         1       0.0       0.0       0.0       0.0       0.4       0.4       0.0
$#      e0        v0
  250000.0       0.0
*PART
$#        title
water
         2         1         2         2         0         0         0         0
*MAT_NULL_TITLE
Water
         2    998.21     -10.0       0.0       0.0       0.0       0.0       0.0
*EOS_GRUNEISEN_TITLE
Water
$#   eosid         c        s1        s2        s3     gamao         a        e0
         2    1647.0     1.921    -0.096       0.0      0.35       0.0  289500.0
$#      v0    unused      lcid
       0.0
$----------------------------------ASCII-DATABASE-------------------------------
*DATABASE_GLSTAT
$#      dt    binary      lcur     ioopt
     0.004         1         0         1
*DATABASE_MATSUM
     0.004         1         0         1
*DATABASE_NCFORC
     0.004         0         0         1
*DATABASE_NODOUT
$#      dt    binary      lcur     ioopt   option1   option2
     0.004         1         0         1       0.0         0
*DATABASE_RBDOUT
     0.004         1         0         1
*DATABASE_BINARY_D3DUMP
$#    cycl      lcdt      beam     npltc    psetid
       0.0         0         0         0         0
*DATABASE_BINARY_D3PLOT
$#      dt      lcdt      beam     npltc    psetid
     0.005         0         0         0         0
$#   ioopt      rate    cutoff    window      type      pset
         0
*DATABASE_EXTENT_BINARY
$#   neiph     neips    maxint    strflg    sigflg    epsflg    rltflg    engflg
         0         0         3         0         1         1         1         1
$#  cmpflg    ieverp    beamip     dcomp      shge     stssz    n3thdt   ialemat
         0         0         0         1         1         3         1         0
$# nintsld   pkp_sen      sclp     hydro     msscl     therm    intout    nodout
         1         0       1.0         0         0         0STRESS    STRESS
$#    dtdt    resplt     neipb   quadsld    cubsld   deleres
         1         0         0
*DEFINE_CURVE_TITLE
sin
$#    lcid      sidr       sfa       sfo      offa      offo    dattyp     lcint
         2         0      0.04     -0.15       0.0       0.0         0         0
$#                a1                  o1
                 0.0                 0.0
                 0.1             6.18034
                 0.2             11.7557
                 0.3            16.18034
                 0.4            19.02113
                 0.5                20.0
                 0.6            19.02113
                 0.7            16.18034
                 0.8             11.7557
                 0.9             6.18034
                 1.0    2.4503000862e-15
                 1.1            -6.18034
                 1.2            -11.7557
                 1.3           -16.18034
                 1.4           -19.02113
                 1.5               -20.0
                 1.6           -19.02113
                 1.7           -16.18034
                 1.8            -11.7557
                 1.9            -6.18034
                 2.0   -4.9005900080e-15
                 2.1             6.18034
                 2.2             11.7557
                 2.3            16.18034
                 2.4            19.02113
                 2.5                20.0
                 2.6            19.02113
                 2.7            16.18034
                 2.8             11.7557
                 2.9             6.18034
                 3.0    7.3508898824e-15
                 3.1            -6.18034
                 3.2            -11.7557
                 3.3           -16.18034
                 3.4           -19.02113
                 3.5               -20.0
                 3.6           -19.02113
                 3.7           -16.18034
                 3.8            -11.7557
                 3.9            -6.18034
                 4.0   -9.8011901804e-15
                 4.1             6.18034
                 4.2             11.7557
                 4.3            16.18034
                 4.4            19.02113
                 4.5                20.0
                 4.6            19.02113
                 4.7            16.18034
                 4.8             11.7557
                 4.9             6.18034
                 5.0    1.2251499796e-14
                 5.1            -6.18034
                 5.2            -11.7557
                 5.3           -16.18034
                 5.4           -19.02113
                 5.5               -20.0
                 5.6           -19.02113
                 5.7           -16.18034
                 5.8            -11.7557
                 5.9            -6.18034
                 6.0   -1.4701800094e-14
                 6.1             6.18034
                 6.2             11.7557
                 6.3            16.18034
                 6.4            19.02113
                 6.5                20.0
                 6.6            19.02113
                 6.7            16.18034
                 6.8             11.7557
                 6.9             6.18034
                 7.0    1.7152100392e-14
                 7.1            -6.18034
                 7.2            -11.7557
                 7.3           -16.18034
                 7.4           -19.02113
                 7.5               -20.0
                 7.6           -19.02113
                 7.7           -16.18034
                 7.8            -11.7557
                 7.9            -6.18034
                 8.0   -1.9602400690e-14
                 8.1             6.18034
                 8.2             11.7557
                 8.3            16.18034
                 8.4            19.02113
                 8.5                20.0
                 8.6            19.02113
                 8.7            16.18034
                 8.8             11.7557
                 8.9             6.18034
                 9.0    2.2052699293e-14
                 9.1            -6.18034
                 9.2            -11.7557
                 9.3           -16.18034
                 9.4           -19.02113
                 9.5               -20.0
                 9.6           -19.02113
                 9.7           -16.18034
                 9.8            -11.7557
                 9.9            -6.18034
                10.0   -2.4502999591e-14
*DEFINE_CURVE_TITLE
bo su
         3         0       1.0       0.3       0.0       0.0         0         0
$#                a1                  o1
                 0.0                20.0
    1.0000000000e+07                20.0
*DEFINE_CURVE_TITLE
load body y
         5         0       1.0       1.0       0.0       0.0         0         0
$#                a1                  o1
                 0.0                 1.0
            200000.0                 1.0
*DEFINE_CURVE_TITLE
x vel
         6         0       1.0       1.0       0.0       0.0         0         0
$#                a1                  o1
                 0.0                 0.0
                 0.2                 0.0
              0.2001              -9.144
                 0.8              -9.144
*DEFINE_CURVE_TITLE
y vel
         7         0       1.0       1.0       0.0       0.0         0         0
$#                a1                  o1
                 0.0                 0.0
                 0.2                 0.0
              0.2001                 0.3
                 0.8                 0.3
*DEFINE_VECTOR
$#     vid        xt        yt        zt        xh        yh        zh       cid
         1       0.0      -1.0       0.0       0.0       0.0       0.0         0
*INCLUDE
mesh_sale.k
*INITIAL_VOLUME_FRACTION_GEOMETRY
$#   fmsid   fmidtyp     bammg    ntrace
         6         1         1         0
$# conttyp   fillopt     fammg        vx        vy        vz    unused    unused
         3         0         2       0.0       0.0       0.0
$#      x0        y0        z0      xcos      ycos      zcos    unused    unused
       1.0       0.0       0.0       0.0       1.0       0.0
*INITIAL_HYDROSTATIC_ALE
$#  alesid     stype     vecid      grav     pbase         -
         1         2         1    9.8065  101300.0
$#     nid    mmgblo
    886400         1
   2000000         2
*INITIAL_VELOCITY
$#    nsid    nsidex     boxid    irigid      icid
         1         0         0         0         0
$#      vx        vy        vz       vxr       vyr       vzr
       6.0       0.0       0.0       0.0       0.0       0.0
$---------------------------------INITIAL-CONDITIONS----------------------------
$*INITIAL_VELOCITY
$         1         0         0         0         0
$       6.0       0.0       0.0       0.0       0.0       0.0
*MAT_RIGID_TITLE
plane
$#     mid        ro         e        pr         n    couple         m     alias
         8    7800.02.10000E11      0.28       0.0       0.0       0.0
$#     cmo      con1      con2
       0.0         0         0
$#lco or a1        a2        a3        v1        v2        v3
*SECTION_SHELL_TITLE
plane
$#   secid    elform      shrf       nip     propt   qr/irid     icomp     setyp
         8         2       1.0         2       1.0         0         0         1
$#      t1        t2        t3        t4      nloc     marea      idof    edgset
      0.01      0.01      0.01      0.01       0.0       0.0       0.0         0
*SET_NODE_LIST
$#     sid       da1       da2       da3       da4    solver       its         -
         3       0.0       0.0       0.0       0.0MECH      1
$#    nid1      nid2      nid3      nid4      nid5      nid6      nid7      nid8
   2000000         0         0         0         0         0         0         0
*SET_MULTI-MATERIAL_GROUP_LIST_TITLE
water
$#  ammsid
$# ammgid1   ammgid2   ammgid3   ammgid4   ammgid5   ammgid6   ammgid7   ammgid8
         2         0         0         0         0         0         0         0
*END
mesh_sale.k
*KEYWORD
*TITLE
$#        title
*ALE_STRUCTURED_MESH
$    mshid       pid      nbid      ebid
$#   mshid      dpid      nbid      ebid    unused    unused    unused    tdeath
         1         6   5000001   3000001
$     nptx      npty      nptz      nid0     lcsid
$#   cpidx     cpidy     cpidz      nid0     lcsid
      1001      1002      1003
*ALE_STRUCTURED_MESH_CONTROL_POINTS
$#    cpid    unused     icase       sfo    unused      offo
      1001                   0       1.0                 0.0
$#                 n                   x               ratio
                   1                -6.0                 0.0
                 121                 6.0                 0.0
      1002                   0       1.0                 0.0
$#                 n                   x               ratio
                   1                -3.0                 0.0
                  61                 3.0                 0.0
      1003                   0       0.0                 0.0
$#                 n                   x               ratio
                   1                -4.0                 0.0
                  81                 4.0                 0.0
*SET_NODE_GENERAL
         1       0.0       0.0       0.0       0.0MECH      1
$#  option     mshid      imin      imax      jmin      jmax      kmin      kmax
SALECPT            1         1       120         1        61         1        81
*SET_NODE_GENERAL
         2       0.0       0.0       0.0       0.0MECH      1
SALECPT            1         1         2         1        61         1        81
*SET_NODE_GENERAL
         4       0.0       0.0       0.0       0.0MECH      1
$#  option     mshid        -x        +x        -y        +y        -z        +z
SALEFAC            1         0         0         1         0         0         0
*SET_NODE_GENERAL
$      SID
        11                                        MECH      1
$   OPTION     MSHID       XMN       XMX       YMN       YMX       ZMN       ZMX
SALEFAC            1                                                 1         1
*SET_NODE_GENERAL
        12       0.0       0.0       0.0       0.0MECH      1
SALEFAC            1         0         1         0         0         0         0
*SET_SEGMENT_GENERAL
$      SID
         1                                        MECH
SALEFAC            1         1         1                   1         1         1
*SET_SOLID_GENERAL
$      SID
$#     sid    solver
         1MECH
SALECPT            1         1       121         1        61         1        81
*SET_SOLID_GENERAL
$      SID
$#     sid    solver
         2MECH
*END
 作者:gjvvhh https://www.bilibili.com/read/cv27122162/ 出处:bilibili
(1条)
评论 点赞
点赞 1 评论 1 收藏 8
