TCL自学笔记-15 hm_entitylist命令
hm_entitylist nodes id
# 输出所有节点的id
hm_entitylist
Returns a list of names or IDs of all entities of the requested type.
Syntax
hm_entitylist entity_type name_or_id ?mode?
Type
HyperMesh Tcl Query
Description
Inputs
entity_type
The type of entity to query.
name_or_id
The type of list to generate. Valid values are:
name - Return the list of names. Only named entity types support this option.
id - Return the list of IDs. All entity types support this option.
mode
An optional argument that specifies which entity types are returned:
active - Return only the active entities. This is the default if not specified.
all - Return both active and inactive entities.
inactive - Return only the inactive entities.
Example
To get the list of node IDs:
To get the list of component names:
hm_entitylist comps name
