Abaqus CAE Python后处理提取每一帧最大等效应力
2024年3月5日 09:21浏览:3090 评论:1 收藏:13
使用Python语言对Abaqus CAE后处理结果进行分析,并提取一个分析步中每一帧的最大等效应力,其中Python代码如下:
from abaqus import *
from abaqusConstants import *
from odbAccess import *
import visualization
myFile=open('DATA.txt','w')
print('********************************\n')
myFile.write('********************************\n')
myOdb=openOdb(path='viewer_tutorial.odb')
myStepValue=myOdb.steps.values()
for step in myStepValue:
print('The current step is: %s.\n'%step.name)
myFile.write('The current step is: %s.\n'%step.name)
frameID=0
for frame in step.frames:
print('The current frame is: %d.\n'%frameID)
myFile.write('The current frame is: %d.\n'%frameID)
frameID=frameID+1
stressValue=frame.fieldOutputs['S'].values
maxMisesValue=0
for misesValue in stressValue:
if misesValue.mises>maxMisesValue:
maxMisesValue=misesValue.mises
print('The maximum mises value of the current frame in current step is: %10.6f\n'%maxMisesValue)
myFile.write('The maximum mises value of the current frame in current step is: %10.6f\n'%maxMisesValue)
myFile.close()
