abaqus分析热轧椭圆空心型钢的抗压强度(二)
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图2
1. Part Geometry
Create a three-dimensional deformable shell part with extruded base feature to represent the elliptical hollow column. Use an approximate part size of 200.0 and name the part EHS.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图3
Create an ellipse with centre and perimeter.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图4
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图5
Pick the centre point or enter X and Y coordinates as 0,0
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图6
Pick a major axis of ellipse or enter X and Y coordinates as 75, 0.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图7
Pick a minor axis of ellipse or enter X and Y coordinates as 0,37.5.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图8
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图9
Click on Done
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图10
Enter base extrusion depth as 300.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图11
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图12
The finished part will be an elliptical hollow section with the major axis diameter of 150 mm and the minor axis diameter of 75 mm. The depth of this stub column is 300mm.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图13
2. Material and section properties
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图14
Define steel as elastic-plastic material.
Click on edit name, enter name as Steel.
Mechanical Elasticity Elastic
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图15
Enter Youngs modulus as 217,700 N/mm2 and Poissons ratio as 0.3.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图16
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图17
Mechanical Pasticity Plastic
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图18
Enter plastic properties as:
Yield stress
Plastic strain
373
0
514
0.18 (assume)
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图19
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图20
Define elliptical tube section.
Name the section as EHS section
Category: Shell
Type: Homogenous
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图21
Enter shell thickness as 4.22 mm and keep all other default options.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图22
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图23
Click on Part EHS Section Assignment
Select the entire section.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图24
Assign EHS Section to the selected elliptical hollow tube.
Shell Offset Definition: Bottom. This will ensure that the entire shell thickness is extruded inside the outer tube diameter.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图25
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图26
3. Assembly
Assemble the parts by clicking on Assembly instances parts EHS. Keep all other values as default.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图27
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图28
Define rigid reference points at top and bottom of the tube.
Assembly features
Tools Tab Reference point
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图29
Select point to act as a reference point or enter X, Y and Z coordinates: 0,0,0 to enter Top reference point.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图30
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图31
Assembly features RP-1 and right click to rename the refence point as Tref.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图32
Repeat the procedure to define the bottom reference point.
Select point to act as a reference point or enter X, Y and Z coordinates: 0,0,300 to enter Bottom reference point.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图33
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图34
Rename RP-2 as BRef
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图35
4. Constraints
Tie top and bottom edge with rigid reference points
First define sets for reference points and tube edges.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图36
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图37
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图38
Define sets for top and bottom reference points as well.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图39
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图40
Tie top reference point with top edge of the elliptical tube.
Create Constraints Name it as TieTop.
Type: Rigid body
This will tie up all the elliptical tubes top edge with the rigid reference point.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图41
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图42
Click on Tie (nodes)
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图43
Select top edge of the tube.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图44
Click on Reference point to choose the top reference point Tref
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图45
When constraints are applied to the tube edges and reference points, it looks like as follows:
5. Defining steps and output requests
Create a single static, Riks step after the initial step. Accept the default output request.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图46
Include the effects of geometric nonlinearity and set the following stopping criteria: Maximum displacement: 10 mm
Degree of freedom (DOF): 3 (which is z direction)
Node Region: TopRef (Top reference point set)
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图47
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图48
Set incrementation type to automatic
Maximum number of increments to 1000
Arc length increment to 0.01
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图49
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图50
6. Boundary condition and loading
Click on Steps initial BCs to define FixBot boundary condition.
The bottom reference point is fixed in all directions with encastre boundary condition.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图51
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图52
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图53
This time, define Displacement rotation boundary condition at the top reference point.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图54
The Top reference point is fixed in all direction except z direction where is the displacement is to be applied in the static Riks step.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图55
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图56
Load top reference point:
StepsApplyDisp and loadTop BC
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图57
Apply 10 mm displacement to top reference point.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图58
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图59
7. Mesh creation and job definition
Go to part and mesh
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图60
Go to seed part and define approximate global size of 10
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图61
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图62
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图63
Go to mesh control and accept all defaults
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图64
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图65
Click on element type and use S4R shell element
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图66
Meshpart
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图67
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图68
Save file as EHS
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图69
Make sure to set working directory to save all files in a single folder.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图70
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图71
Define job now and accept all defaults
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图72
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图73
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图74
JobsEHS_FE and data check
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图75
Data check completed with no errors.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图76
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图77
JobsEHS_FE - Submit
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图78
Then monitor the job
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图79
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图80
Job is completed without errors.
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图81
8. Post-processing
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图82
Load deflection curve
Right click and Results
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图83
Click on XYdata and ODB field output
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图84
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图85
Click on position: Unique Nodal
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图86
Click on displacement U3
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图87
Click on Elements Nodesets and TopRef
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图88
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图89
Plot and save
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图90
But this will give displacement versus arc length, we need load versus displacement curves.
Click on XYdata, ODB field output, reaction force and RF3, TopRef, plot and save
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图91
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图92
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图93
XYData Operate on Data
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图94
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图95
Click on combine
Double u3
Double click on RF3
Divide RF3 by 1000 to convert it into kN
Plot and save as Load-Defl
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图96
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图97
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图98
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图99
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图100
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图101
Ultimate load, Fu (kN)
End shortening at Fu
(mm)
Test
554
FE
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图102
Deflected shape
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图103
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图104
abaqus分析热轧椭圆空心型钢的抗压强度(二)的图105
