三维桁架有限元分析MATLAB代码
The finite element analysis of three-dimensional truss based on MATLAB and ABAQUS software
A 3D Truss structure has to be designed to sustain a total load 4P = 400kN, which P = 100kN. N as applied on nodes 1,2,3 and 4 as shown in Fig. 1. The foundation connecting this truss to the ground is designed support configuration I and support configuration II. Assume that the z = 0 plane represents the ground of the structure The truss members are composed of ASME A335-grade chrome steel, with the elastic modulus, yield strength, and safety factor as specified below.
E =210GPa.,SY = 205MPa.,SF = 2.5
That means the stress value in truss elements shound not exceeds 205/2.5=82MPa.
(a)
三维桁架有限元分析MATLAB代码的图1
(b)
三维桁架有限元分析MATLAB代码的图2
Fig. 1 Two support configurations
The support configurations I and configurations II's node numbers are shown in the following Fig. 2 and Fig. 3, respectively。
三维桁架有限元分析MATLAB代码的图3
Fig. 2 The node of support configurations I
三维桁架有限元分析MATLAB代码的图4
Fig. 3 The node of support configurations II
三维桁架有限元分析MATLAB代码的图5
The two structures are generated using MATLAB as shown in Fig. 4.
(a)
三维桁架有限元分析MATLAB代码的图6
(b)
三维桁架有限元分析MATLAB代码的图7
Fig. 4 Two support configurations were implemented using MATLAB.
The MATLAB program algorithm flowchart is shown in Fig. 11.
三维桁架有限元分析MATLAB代码的图8
Fig. 11 Algorithm flowchart
See matlab program for specific code.
3.1 nodal coordinates:
三维桁架有限元分析MATLAB代码的图9
For case I:
d1=2000;d2=6000;d3=6000;h1=6000;h2=12000; %mm
%Node x-axis direction coordinates, mm
x=[-d1 d1 d1 -d1 -d2 d2 d2 -d2 -d3 d3 d3 -d3]/2;
%Node y-axis direction coordinates, mm
y=[d1 d1 -d1 -d1 d2 d2 -d2 -d2 d3 d3 -d3 -d3]/2;
%Node z-axis direction coordinates, mm
z=[h2 h2 h2 h2 h1 h1 h1 h1 0 0 0 0];
For case II:
d1=2000;d2=6000;d3=10000;h1=6000;h2=12000; %mm
3.2 material properties:
In order to satisfy that the maximum stress in the bars does not exceed SY/SF=205/2.5=82Mpa, it is necessary to select the minimum value of the cross-section according to the stress calculated by the Matlab program. For Case 1, when the cross-section area of each rod is 1.35mm2, as shown in Fig. 12 (a), the maximum stress is 81.892Mpa, which meets the requirement. For working condition 2, when the cross sectional area of each rod is 1.35mm2, as shown in Fig. 12 (b), the maximum stress is 81.892Mpa, which meets the requirement.
三维桁架有限元分析MATLAB代码的图10
(a)    Case I
三维桁架有限元分析MATLAB代码的图11
(b) Case II
Fig. 12 Calculation results for different structural stresses
Thus, for case I, the matlab statement is:
%Define cross-sectional area and modulus of elasticity, mm2 and MPa
A=1.35;E=2.1E5;
Thus, for case II, the matlab statement is:
A=1.35;E=2.1E5;
1.3 element connectivity matrices:
三维桁架有限元分析MATLAB代码的图12
Fig. 13 Node connection number of the unit
Matlab code:
%Connection information: number, local node 1 number, local node 2 number, cross sectional area, modulus of elasticity
ele=[1 1 2 A E;2 2 3 A E;3 3 4 A E;4 1 4 A E;5 1 3 A E;6 2 4 A E;7 5 6 A E;...
  8 6 7 A E;9 7 8 A E;10 5 8 A E;11 1 5 A E;12 2 6 A E;13 3 7 A E;...
  14 4 8 A E;15 1 8 A E;16 3 8 A E;17 3 6 A E;18 1 6 A E;19 5 9 A E;...
  20 8 12 A E;21 7 11 A E;22 6 10 A E;...
  23 8 11 A E;24 7 12 A E;25 7 10 A E;26 6 11 A E;27 5 10 A E;28 6 9 A E;29 5 12 A E;30 8 9 A E];
3.4elemental stresses and nodal displacements:
Matlab code:
for iEle =1:EleCount
   %Calculate the displacement in local coordinates of the rod
   n1=ele(iEle,2);n2=ele(iEle,3);
   R=CoordTransform([x(n1) x(n2)],[y(n1) y(n2)],[z(n1) z(n2)],BarLength(iEle));
   localU = R*[U(3*n1-2:3*n1,1);U(3*n2-2:3*n2,1)];
   Strain(1, iEle)=[-1/BarLength(iEle) 1/BarLength(iEle)]*localU; %Strain
   Stress(1, iEle)=ele(iEle,5)* Strain(1, iEle); %Stress
   AxialForce(1, iEle)=ele(iEle,4)* Stress(1, iEle); %AxialForce
End
%Save displacements, stresses and axial forces to a text file.
fp=fopen('Result.txt','a');
str = [char(13,10)','U',' ',num2str(U'),char(13,10)','Stress',' ',...
  num2str(Stress),char(13,10)','AxialForce',' ',num2str(AxialForce)];
fprintf(fp,str);
Therefore, for case I, the displacement, stress and axial force results are:
三维桁架有限元分析MATLAB代码的图13
Therefore, for case II, the displacement, stress and axial force results are:
三维桁架有限元分析MATLAB代码的图14
三维桁架有限元分析MATLAB代码的图15
三维桁架有限元分析MATLAB代码的图16
三维桁架有限元分析MATLAB代码的图17
Fig. 17 Compared maximum stress results under different d3.
以下内容为付费内容,请购买后观看
付费内容为基于有限单元法可以计算任意三维桁架的应力和变形(采用matlab)源程序。
