单位制
MASS |
LENGTH |
TIME |
FORCE |
STRESS |
ENERGY |
DENSITY |
YOUNG’s |
Velocity (56.3KMPH) |
GRAVITY |
kg |
m |
s |
N |
Pa |
Joule |
7.83E+03 |
2.07E+11 |
15.65 |
9.806 |
kg |
cm |
s |
1.e-02N |
7.83E-03 |
2.07E+09 |
1.56E+03 |
9.81E+02 |
kg |
cm |
ms |
1.e+04N |
7.83E-03 |
2.07E+03 |
1.56 |
9.81E-04 |
kg |
cm |
us |
1.e+10N |
7.83E-03 |
2.07E-03 |
1.56E-03 |
9.81E-10 |
kg |
mm |
ms |
KN |
GPa |
KN-mm |
7.83E-06 |
2.07E+02 |
15.65 |
9.81E-03 |
gm |
cm |
s |
dyne |
dy/cm2 |
erg |
7.83E+00 |
2.07E+12 |
1.56E+03 |
9.81E+02 |
gm |
cm |
us |
1.e+07N |
Mbar |
1.e7Ncm |
7.83E+00 |
2.07E+00 |
1.56E-03 |
9.81E-10 |
gm |
mm |
s |
1.e-06N |
Pa |
7.83E-03 |
2.07E+11 |
1.56E+04 |
9.81E+03 |
gm |
mm |
ms |
N |
MPa |
N-mm |
7.83E-03 |
2.07E+05 |
15.65 |
9.81E-03 |
ton |
mm |
s |
N |
MPa |
N-mm |
7.83E-09 |
2.07E+05 |
1.56E+04 |
9.81E+03 |
lbfs2/in |
in |
s |
lbf |
psi |
lbf-in |
7.33E-04 |
3.00E+07 |
6.16E+02 |
386 |
slug |
ft |
s |
lbf |
psf |
lbf-ft |
15.2 |
4.32E+09 |
51.33 |
32.17 |
kgfs2/mm |
mm |
s |
kgf |
kgf/mm2 |
kgf-mm |
8.02E-10 |
7.00E+02 |
1.56E+04 |
(Japan) |
kg |
mm |
s |
mN |
1000Pa |
7.83E-06 |
2.07E+08 |
9.81E+02 |
gm |
cm |
ms |
100000Pa |
7.83E+00 |
2.07E+06 |
As points of reference, the mass density and Young’s Modulus of steel are provided in each system of units. “GRAVITY” is gravitational acceleration.
