ADAMS建模命令(可以通过命令建模,同时通过修改命令种参数可以对模型进行修改)
Adams/View MD Adams R3 (built Mar 6 2008)
Graphics: OpenGL
Using software OpenGL overlay plane emulation
Enter a command, '?', or 'help'.
//*设置单位及其重力加速度方向*//
! New Session - Set units, Create a model, and set gravity
default units len=mm mass=kg force=newton
model create model="model_1" fit_to_view=no
part attrib part_name=ground name_vis=off
part modify rigid_body mass_properties part_name=ground material=.materials.steel
force create body gravitational gravity=gravity &
x_comp=0 y_comp=-9806.65 z_comp=0
//*设置坐标系统*//
! SELECT OBJECT
undo begin
default coordinate_system default_coordinate_system=.model_1
undo end
interface cmd_window display=toggle
//*创建点—加到ground上*//
! CREATE POINT
undo begin
point create point = .model_1.ground.POINT_1 location=-500.0, 150.0, 0.0
group modify group=SELECT_LIST object=.model_1.ground.POINT_1
undo end
//*创建点—加到part上*//
! CREATE POINT
undo begin
point create point = .model_1.PART_2.POINT_3 location=-250.0, 300.0, 0.0
group modify group=SELECT_LIST object=.model_1.PART_2.POINT_3
undo end
