[案例分析]基于SU2的二维超声速空腔非定常流动计算
空腔外形在内埋武器舱、起落架舱、超燃冲压发动机燃烧室等先进飞行器部件中有着广泛应用。本文以参考文献(Zhang and Rona, 1998, Journal of Sound and Vibration)提供的空腔外形为对象,采用ddes方法计算二维超声速空腔流动,检验SU2对于超声速非定常流场的模拟能力。
![[案例分析]基于SU2的二维超声速空腔非定常流动计算的图1](https://pic2.zhimg.com/v2-cd2362c918f54c6c85d70c0d70211f41_r.jpg)
图 1 二维超声速空腔试验纹影结果
![[案例分析]基于SU2的二维超声速空腔非定常流动计算的图2](https://pic4.zhimg.com/80/v2-9367156e64f4f975d871cf56650cc5d7_hd.jpg)
2.网格生成
计算网格直接在pointwise软件中生成,网格包括空腔内部及平板上方两个网格块。空腔内部网格块为321×149个网格点,平板上方网格块为1011×359个网格点。平板上方边界层内第一层网格高度为4.5×10-7米。
![[案例分析]基于SU2的二维超声速空腔非定常流动计算的图3](https://pic3.zhimg.com/80/v2-9a6692a70fba3100793546199956965e_hd.jpg)
(a)二维空腔流动全局计算网格(i,j方向每8个网格点显示1个)
(b)二维空腔流动局部计算网格(i,j方向每4个网格点显示1个)
3.SU2求解器设置
3.1 流场求解cfg文件设置
下面介绍二维超声速空腔算例的参数设置。
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % % Physical governing equations (EULER, NAVIER_STOKES, % WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY, % POISSON_EQUATION) PHYSICAL_PROBLEM= NAVIER_STOKES % % Specify turbulent model (NONE, SA, SA_NEG, SST) KIND_TURB_MODEL= SA HYBRID_RANSLES= SA_EDDES % % Mathematical problem (DIRECT, CONTINUOUS_ADJOINT) MATH_PROBLEM= DIRECT % % Restart solution (NO, YES) RESTART_SOL= NO %initialization TESTCASE_TYPE= CAVITY % -------------------- COMPRESSIBLE FREE-STREAM DEFINITION --------------------% % % Mach number (non-dimensional, based on the free-stream values) MACH_NUMBER= 1.5 % % Angle of attack (degrees, only for compressible flows) AOA= 0.0 % % Init option to choose between Reynolds (default) or thermodynamics quantities % for initializing the solution (REYNOLDS, TD_CONDITIONS) INIT_OPTION= REYNOLDS % % Free-stream option to choose between density and temperature (default) for % initializing the solution (TEMPERATURE_FS, DENSITY_FS) FREESTREAM_OPTION= TEMPERATURE_FS % % Free-stream pressure (101325.0 N/m^2, 2116.216 psf by default) FREESTREAM_PRESSURE= 5.38E4 % % Free-stream temperature (288.15 K by default) FREESTREAM_TEMPERATURE= 200 % % Reynolds number (non-dimensional, based on the free-stream values) REYNOLDS_NUMBER= 1.35E6 % % Reynolds length (1 m by default) REYNOLDS_LENGTH= 0.045 % % Compressible flow non-dimensionalization (DIMENSIONAL, FREESTREAM_PRESS_EQ_ONE, % FREESTREAM_VEL_EQ_MACH, FREESTREAM_VEL_EQ_ONE) REF_DIMENSIONALIZATION= FREESTREAM_VEL_EQ_ONE
% ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % % Reference origin for moment computation REF_ORIGIN_MOMENT_X = 0.25 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 % % Reference length for pitching, rolling, and yawing non-dimensional moment REF_LENGTH= 1.0 % % Reference area for force coefficients (0 implies automatic calculation) REF_AREA= 0.045 % ------------------------- UNSTEADY SIMULATION -------------------------------% % % Unsteady simulation (NO, TIME_STEPPING, DUAL_TIME_STEPPING-1ST_ORDER, % DUAL_TIME_STEPPING-2ND_ORDER, TIME_SPECTRAL) %UNSTEADY_SIMULATION= NO UNSTEADY_SIMULATION= DUAL_TIME_STEPPING-2ND_ORDER % % Time Step for dual time stepping simulations (s) % U_inf = 425 - L=4.5E-2 dt=0.002 - UNST_TIMESTEP= 2.12E-7 % % Total Physical Time for dual time stepping simulations (s) UNST_TIME= 1.06E-2 % % Unsteady Courant-Friedrichs-Lewy number of the finest grid UNST_CFL_NUMBER= 0.0 % % Number of internal iterations (dual time method) UNST_INT_ITER= 30 % % Iteration number to begin unsteady restarts UNST_RESTART_ITER= 2
% -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % % Navier-Stokes wall boundary marker(s) (NONE = no marker) MARKER_HEATFLUX= ( wall-down, 0.0 ) % Format: (inlet marker, temperature, static pressure, velocity_x, % velocity_y, velocity_z, ... ), i.e. primitive variables specified. MARKER_SUPERSONIC_INLET= ( inlet, 200,5.38E4,425.22,0,0 ) MARKER_SUPERSONIC_OUTLET= ( outlet ) MARKER_SYM= ( wall-up ) % % Farfield boundary marker(s) (NONE = no marker) %MARKER_FAR= ( FARFIELD ) % % Marker(s) of the surface to be plotted or designed MARKER_PLOTTING= ( wall-down ) % % Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated MARKER_MONITORING= ( wall-down ) % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % % Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= GREEN_GAUSS % % Courant-Friedrichs-Lewy condition of the finest grid CFL_NUMBER= 10 % % Adaptive CFL number (NO, YES) CFL_ADAPT= NO % % Parameters of the adaptive CFL number (factor down, factor up, CFL min value, % CFL max value ) CFL_ADAPT_PARAM= ( 1.5, 0.5, 1.0, 100.0 ) % % Number of total iterations EXT_ITER= 50000 % % Linear solver for the implicit formulation (BCGSTAB, FGMRES) LINEAR_SOLVER= BCGSTAB % % Min error of the linear solver for the implicit formulation LINEAR_SOLVER_ERROR= 1E-6 % % Max number of iterations of the linear solver for the implicit formulation LINEAR_SOLVER_ITER= 20 % -------------------------- MULTIGRID PARAMETERS -----------------------------% % % Multi-Grid Levels (0 = no multi-grid) MGLEVEL= 0 % % Multi-grid cycle (V_CYCLE, W_CYCLE, FULLMG_CYCLE) MGCYCLE= W_CYCLE % % Multi-grid pre-smoothing level MG_PRE_SMOOTH= ( 1, 2, 3, 3 ) % % Multi-grid post-smoothing level MG_POST_SMOOTH= ( 0, 0, 0, 0 ) % % Jacobi implicit smoothing of the correction MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 ) % % Damping factor for the residual restriction MG_DAMP_RESTRICTION= 0.95 % % Damping factor for the correction prolongation MG_DAMP_PROLONGATION= 0.95 % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC, % TURKEL_PREC, MSW) CONV_NUM_METHOD_FLOW= JST % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the flow equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_FLOW= YES % % Slope limiter (VENKATAKRISHNAN, MINMOD) SLOPE_LIMITER_FLOW= VENKATAKRISHNAN % % Coefficient for the limiter (smooth regions) VENKAT_LIMITER_COEFF= 0.03 % % 2nd and 4th order artificial dissipation coefficients JST_SENSOR_COEFF= ( 0.5, 0.02 ) % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT) TIME_DISCRE_FLOW= EULER_IMPLICIT % -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------% % % Convective numerical method (SCALAR_UPWIND) CONV_NUM_METHOD_TURB= SCALAR_UPWIND % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the turbulence equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_TURB= NO % % Time discretization (EULER_IMPLICIT) TIME_DISCRE_TURB= EULER_IMPLICIT
% ---------------- ADJOINT-FLOW NUMERICAL METHOD DEFINITION -------------------% % Adjoint problem boundary condition (DRAG, LIFT, SIDEFORCE, MOMENT_X, % MOMENT_Y, MOMENT_Z, EFFICIENCY, % EQUIVALENT_AREA, NEARFIELD_PRESSURE, % FORCE_X, FORCE_Y, FORCE_Z, THRUST, % TORQUE, FREE_SURFACE, TOTAL_HEAT, % MAXIMUM_HEATFLUX, INVERSE_DESIGN_PRESSURE, % INVERSE_DESIGN_HEATFLUX) OBJECTIVE_FUNCTION= DRAG % % Convective numerical method (JST, LAX-FRIEDRICH, ROE) CONV_NUM_METHOD_ADJFLOW= JST % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the adjoint flow equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_ADJFLOW= YES % % Slope limiter (NONE, VENKATAKRISHNAN, BARTH_JESPERSEN, VAN_ALBADA_EDGE, % SHARP_EDGES, WALL_DISTANCE) SLOPE_LIMITER_ADJFLOW= NONE % % Coefficient for the sharp edges limiter ADJ_SHARP_LIMITER_COEFF= 3.0 % % 2nd, and 4th order artificial dissipation coefficients ADJ_JST_SENSOR_COEFF= ( 0.0, 0.01 ) % % Reduction factor of the CFL coefficient in the adjoint problem CFL_REDUCTION_ADJFLOW= 0.75 % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT) TIME_DISCRE_ADJFLOW= EULER_IMPLICIT % % Adjoint frozen viscosity (NO, YES) FROZEN_VISC_CONT= YES % --------------------------- CONVERGENCE PARAMETERS --------------------------% % % Convergence criteria (CAUCHY, RESIDUAL) % CONV_CRITERIA= RESIDUAL % % Residual reduction (order of magnitude with respect to the initial value) RESIDUAL_REDUCTION= 3 % % Min value of the residual (log10 of the residual) RESIDUAL_MINVAL= -15 % % Start convergence criteria at iteration number STARTCONV_ITER= 10 % % Number of elements to apply the criteria CAUCHY_ELEMS= 100 % % Epsilon to control the series convergence CAUCHY_EPS= 1E-6 % % Function to apply the criteria (LIFT, DRAG, NEARFIELD_PRESS, SENS_GEOMETRY, % SENS_MACH, DELTA_LIFT, DELTA_DRAG) CAUCHY_FUNC_FLOW= DRAG
% ------------------------- INPUT/OUTPUT INFORMATION --------------------------% % % Mesh input file MESH_FILENAME= cavity-LD3-fine.su2 % % Mesh input file format (SU2, CGNS, NETCDF_ASCII) MESH_FORMAT= SU2 % % Mesh output file MESH_OUT_FILENAME= mesh_out.su2 % % Restart flow input file SOLUTION_FLOW_FILENAME= restart_flow.dat % % Restart adjoint input file SOLUTION_ADJ_FILENAME= solution_adj.dat % % Output file format (PARAVIEW, TECPLOT, STL) OUTPUT_FORMAT= TECPLOT_BINARY % % Output file convergence history (w/o extension) CONV_FILENAME= history % % Output file restart flow RESTART_FLOW_FILENAME= restart_flow.dat % % Output file restart adjoint RESTART_ADJ_FILENAME= restart_adj.dat % % Output file flow (w/o extension) variables VOLUME_FLOW_FILENAME= flow % % Output file adjoint (w/o extension) variables VOLUME_ADJ_FILENAME= adjoint % % Output objective function gradient (using continuous adjoint) GRAD_OBJFUNC_FILENAME= of_grad.dat % % Output file surface flow coefficient (w/o extension) SURFACE_FLOW_FILENAME= surface_flow % % Output file surface adjoint coefficient (w/o extension) SURFACE_ADJ_FILENAME= surface_adjoint % % Writing solution file frequency WRT_SOL_FREQ= 100 % % Writing convergence history frequency WRT_CON_FREQ= 1 % Writing solution file frequency for physical time steps (dual time) WRT_SOL_FREQ_DUALTIME= 30 WRT_SURF_FREQ_DUALTIME= 1
3.2 并行运算脚本sh文件设置
在算例cfg文件所在目录,创建如下内容的sh文件,采用sbatch命令提交即可。
#!/bin/bash #SBATCH -N 7 #并行节点数 #SBATCH -n 168 #并行cpu数,=24*节点数 #SBATCH --job-name=cavity #job的名称 #SBATCH --ntasks-per-node=24 #每个节点用到的cpu数,无需修改 #SBATCH --output=%j.out #算例运行过程中在屏幕上显示的信息 #SBATCH --error=%j.err #报错信息 mpirun SU2_CFD ddes_2d_cavity_unsteady.cfg #流场求解 mpirun SU2_SOL ddes_2d_cavity_unsteady.cfg #输出tecplot结果文件
4.结果分析
4.1 与试验结果对比
图3将SU2计算的二维超声速空腔流场与试验纹影进行了对比。可以看到计算结果清晰捕捉到了空腔前缘斜激波和各种运动波系结构,计算得到的波系结构形状、相对位置等与试验结果基本一致。
![[案例分析]基于SU2的二维超声速空腔非定常流动计算的图5](https://pic1.zhimg.com/80/v2-bb0ff9ff783e341ea7b87a11df161e3c_hd.jpg)
(a)
![[案例分析]基于SU2的二维超声速空腔非定常流动计算的图6](https://pic3.zhimg.com/80/v2-a43967251b3ebb1e80d81fa842ca8a2a_hd.jpg)
(b)
图 3 试验纹影结果与计算结果对比
4.2 腔内波系结构
![[案例分析]基于SU2的二维超声速空腔非定常流动计算的图7](https://pic3.zhimg.com/80/v2-730967fe373830880d3459a550705ade_hd.jpg)
(a)
![[案例分析]基于SU2的二维超声速空腔非定常流动计算的图8](https://pic2.zhimg.com/80/v2-024862346034ea3e0abb43a8124803d5_hd.jpg)
(b)
图 4 超声速空腔内部流动结构
图4展示了SU2计算得到的超声速空腔内部流动结构。可以清晰看到空腔内部各种尺度的旋涡结构以及运动激波,以及各种流动结构之间的相互作用过程。
5.结论
采用SU2计算了二维超声速空腔流场,计算得到的波系结构与试验纹影结果符合一致,表明SU2具备模拟二维空腔等超声速非定常流场的能力。
本文转自知乎专栏:SU2:学习与应用,原帖地址:https://zhuanlan.zhihu.com/p/62405162,感谢原作者。
![[免费案例]Ensight案例教程分享](https://img.jishulink.com/cimage/245b3ca9e2c939e40491a25edae94515.jpeg?image_process=resize,fw_512,fh_288,)
全部评论 (0)
