Moldflow CAD Doctor2.0 功能ߡ
2006年2月18日 浏览:186745
Moldflow CAD Doctor?BR>
Moldflow CAD Doctor?is a powerful tool for checking, correcting, healing, and simplifying solid models imported from popular 3D CAD systems in preparation for analysis using Moldflow Plastics Advisers?(MPA? or Moldflow Plastics Insight?(MPI?.
Moldflow CAD Doctor supports the import of IGES and CATIA V4 formats. Additionally, Moldflow CAD Doctor interfaces with Moldflow Design Link?(MDL? to allow for the import of CATIA V5? Parasolid? Pro/ENGINEER? SolidWorks? and STEP models.
Moldflow CAD Doctor outputs models in Moldflow抯 proprietary UDM format which can then be imported into MPI 5.1 or later and MPA 7.2 or later.
Capabilities
Directly import and manipulate IGES and CATIA V4 models
Import through MDL other native CAD formats such as CATIA V5, Parasolid, Pro/ENGINEER, SolidWorks and STEP models
Perform diagnostics check to assess over 30 different types of model quality problems
Choose which types of model checks are to be performed as well as adjust the tolerance or thresholds used in these checking operations
Intelligent default tolerance and threshold values suitable for MPA and MPI supplied with the software
Quickly locate quality issues with intelligent, colored error assignment on model surfaces
Automatically stitch free edges in the model
Preview the effectiveness of the free edge stitching process and if necessary adjust the tolerance value
Perform crucial geometry healing step to insure the integrity of the model
Optimize the model for use with MPA or MPI by simplifying features that add complexity to the geometry
Simplification tools can be used with small fillets, radii, slivers, chamfers, lettering, tool symbols, embossing, and logos
Geometry creation and editing tools give the user the flexibility of not having to revert to a CAD system to make simple geometry modifications
Create points, curves, faces and surfaces through numerous geometry creation tools
Export quality solid models for use with MPA and MPI simulations
Measure distances, curvature, included angles and coordinates of various entities directly on the model
Geometry Import Options
IGES
CATIA V4 *
CATIA V5 **
Parasolid **
Pro/ENGINEER **
SolidWorks **
STEP **
* Requires optional add-on license
** Requires optional Moldflow Design Link (MDL) add-on module
Capabilities
IGES
CATIA V4 *
CATIA V5 **
Parasolid **
Pro/ENGINEER **
SolidWorks **
STEP **
点赞 评论 收藏
