5. High Pressure Die Casting
A process generally applied to non-ferrous alloys(Al, Mg, Zn), high pressure die casting is a method where the melt is fed into the mould by pressurization to cast metals at high-speed. Defects such as gas holes, cold shut, and inclusion entrapment are taken care of by appropriately controlling the shape of the runner, the cross section of the ingate, the position and size of the overflow, etc. Problems arising from the overheat of the mould, which in return is a result of repetitive operation, such as shrinkage defects, coarse structure, and delay in cycle time can be solved by installing an appropriate cooling line and consistently maintaining the temperature of the mould.
全部评论 (0)
