Dynamic Modeling and Simulation--AMESim
Dynamic Modeling and Simulation Traditionally it抯 kwon two approaches for simulation ?Signal Port and the Multi Port method that treats power flow and is derived from de Bond Graph technique. |
Signal Port On the signal port approach, connections between elements are defined via ports, which must be specified the system state variables and each connection correspond to only one variable. This makes modeling extremely complex in systems where there is power flux, characterized by the exchange of two variables, that is, the power variables: pressure/flow rate, force/velocity, etc Block Diagram (Hydraulic Circuit) |
In order to simplify power system抯 dynamic modeling, the Bond Graph approach is each time more being used in the academic and industrial environment. A clear description between the two approaches is available at the article: How to create Good Models without writing a single line of code, by: Michel Lebrun e Claude Richards. (Multi Ports (Hydraulic Circuit) |
One of the world抯 most distinguished dynamic modeling system applying the Bond Graph technique is AMESim - Advanced Modeling Environment for Simulations, by the French company IMAGINE. For more than 10 years, IMAGINE has being successful on consulting projects in Europe companies such as Aerospatiale, Bosch, Dassault, Mercedes Benz General Motors, Lucas Diesel, Otis, PSA Peugeot Citro雗, Renault, Siemens, Thomson. AMESim is capable of providing full solutions on dynamic modeling in fluid power, mechanical, thermo-fluids and control system. It has more than 25 open libraries allowing customization. |
IMAGINE was created in 1986 by professorMichel Lebrun from University of Lyon, whom was formally involved at the EKOFISK project, specifically at the modeling and simulation area of PHILIS petroleum platform levering at the North sea. |
AMESim does not require extensive specialization to be manipulated, in a way that engineers can maintain their focus on the understanding and analysis of their study system. Being one only tool capable of so many applications, there is a considerable saving in people training. Making use of its reusable models, AMESim also reduces the development cycle and enlarges the R&D Know-How.
KEOHPS ?In Brazil and countries such: Argentina, Chile, Uruguay, Paraguay, Bolivia, Ecuador, Colombia, Venezuela, Guiana and Suriname, AMESim is exclusively represented by KEOHPS.Not only South America AMESim抯 exclusive distributor, KEOHPS also provides lectures and training sections and consulting services trough highly capable corps of technical consultants. One of the first institutions to make use of AMESim was Federal University of Santa Catarina on its Mechanical Engineering抯 master program. Today AMESim is available at others educational institutions all over the country and is on the process of implementation in automotive, industrial and aero spatial organizations as EMBRAER and BOSCH. |
You can visualize AMESim environment trough tutorials and follow the process of modeling and simulation. A presentation on the concepts behind the modeling methods is also available.
Companies and educational institutions may ask for an evaluation license for AMESim. We can send lots more of materials regarding AMESim抯 applications in many different areas, many of them written with the help of the most respected companies of the world using AMESim.
