[AMESim4.3]Exhaust Gas Aftertreatment
A new product for the AMESim?platform is now being launched by IMAGINE: IFP-Exhaust.
This innovative tool is the result of the partnership signed between IMAGINE and the IFP (Institut Fran鏰is du P閠role) and allows R&D engineers to simulate with high accuracy the complex emissions of exhaust systems.
It offers an open architecture for different analysis and optimization in exhaust gas aftertreatment:
  • Load & Regeneration Cycles for DPF Durability [AMESim4.3]Exhaust Gas Aftertreatment的图1
  • Coupling with Engine Control Strategy
  • Catalytic Converter Efficiency
  • Light-off Optimization.
  • Best location of the catalyst converter
  • Insulation or engine setting before light-off
Benefits
Thanks to the IFP-Exhaust library, AMESim?makes it possible to consider the chemical reactions resulting from 12 different gas species, taking into consideration all kinetic aspects. Furthermore, the key feature resides in the ready-to-use models of a 3-way catalytic converter, HC trap, Nox trap, oxygen storage, diesel oxidation catalyst, diesel particulate filter, etc. IFP-Exhaust also provides validated components for pipes, volumes, exchangers, sensors & valves to model the after-treatment components right up to the complete exhaust line. A full after-treatment system of the exhaust line is thus defined and enables the analysis of the HC, CO and NOx conversion efficiency.
[AMESim4.3]Exhaust Gas Aftertreatment的图2
Key points
  • HC, CO and NOx conversion efficiency calculation
  • Soot Particles Storage
  • Transient thermal & chemical kinetics
  • Validation with experiments thanks to IFP expertise
  • Adapted & state of the art stiff solver for high dynamic stiff kinetic mechanism
  • Users can add linkage to external kinetic codes, e.g. CHEMKIN
  • Fully integrated in the AMESim Platform
  • Electronic Control Unit integration with the Matlab?Simulink?interface
(1条)
呵呵,能给翻译一下么?
点赞 评论 1 收藏
