顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
Workbench中错误提示:An error occurred while starting..? 20
浏览: 8648 回答: 4
电脑以前没有被网管监控,因此ANSYS软件均可用,当天晚上因计算需要没有关闭电脑(且workbench也未关闭),当天很多人选择了关机。第二天发现workebnch不能进行运算,但网格划分均可完成,而其他人的ansys完全不能打开。申请软件权限开通以后,且在Workbench中进行任何求解时均会出现错误提示:An error occurred while starting the solver module. Please refer to the Troubleshooting section in the ANSYS Mechanical user guide.参考http://www.eureka.im/5172.html的解决方式,均解决不了,不能求解。workbench错误提示.png
错误提示及解决方法如下:
An error occurred while starting the ANSYS solver module. Please refer to the Troubleshooting section in the ANSYS Workbench Manual
Explanation: This problem occurs when trying to solve an analysis in Workbench that is stored on a network drive using a UNC path. For example: computer_namefoldername. In ANSYS Workbench 12.0 when a solve is started it runs the Ansys120.exe executable. This in turn runs the Windows Cmd.exe interface. The Windows Cmd.exe interface is unable to handle UNC paths which cause this problem.
There are two possible resolutions/workarounds for this issue:
Resolution 1: Map the network drive to a drive letter on the local machine to resolve this issue.
Windows Explorer > Tools menu > Map Network Drive.
Select a drive letter and enter the UNC path to the directory where the analysis is stored, for example: computer_namefoldername
Resolution 2: The following Microsoft Base article is a workaround to allow the Cmd.exe interface to run using UNC paths. <a target=_blank href="http://support.microsoft.com/kb/156276">http://support.microsoft.com/kb/156276</a>http://support.microsoft.com/kb/156276
Resolution 3: This problem can also occur when the ANSYS Mechanical package is not installed on the machine. Check the install directory for a `<install_dir>v120ansys` folder (Example: Crogram FilesANSYS Incv120ansys). If this folder does not exist then the Mechanical package is not installed.
请问如何做才能使软件正常使用?(软件权限均已开通)
ANSYS 结构CAE 机械电子
全部回答 (4)
数理统计 2022年11月18日
2022年11月18日
看惯^一切~ 2020年10月22日
这个问题我已经解决,解决方法是,在mechanical窗口下的tool-solve process settings 里点击advanced 把max number of utilized cores改成1
2020年10月22日
小小木 2020年5月7日
换版本都没有用
2020年5月7日
木昙 2019年7月26日
同求答案
2019年7月26日
相似问题
查看全部
  • error occurred while starting the solver module? 5个回答
    在ansysworkbench中solve的时候总是出现“An error occurred while starting the solver module. Please refer to the Troubleshooting section in the ANSYS Mechanical User Guide.”这个错误的提示,试了好多遍,下了好多次ansys,总是会出现这个?关闭过电脑管
  • Ansys an error occurred while starting the solve module please refer to the troubleshooting section in the ANSYS Mechanical User Guide? 3个回答
    静态分析求解的时候解不出来,总是提示an error occurred while starting the solve module please refer to the troubleshooting section in the ANSYS Mechanical User Guide
  • 关于下面这个帖子中提到的问题,有大佬知道为什么吗? 3个回答
    Xingsheng Sun (Mechanical)(OP)18 Aug 21 21:51 Dear folks, I am trying to use C++ VUMAT in the abaqus on the university supercomputer, but it does not work. I have successfully tested the C++ VUMAT and
推荐阅读
ABAQUS中级教程合集--搞定滞回曲线
1点 1点
¥299
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
应用ANSYS瞬态动力学法模拟啮合齿轮的高速转动
夏日星空 夏日星空
¥35
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
混凝土材性试块拉压数值模拟(ABAQUS通法建模初级案例3)
大平-结构工程 大平-结构工程
¥299
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ABAQUS桁架结构强度分析
ABAQUS桁架结构强度分析
wj_2704 wj_2704
¥500
ADAS功能软件基础介绍
ADAS功能软件基础介绍
Alex王 Alex王
免费
abaqus lamb波传播分析
abaqus lamb波传播分析
abaquser abaquser
¥25
TurboTides TurboTides
免费
场景仿真加速智能网联开发测试进程
场景仿真加速智能网联开发测试进程
海克斯康设计与仿真 海克斯康设计与仿真
免费
ANSYS speos汽车信号灯案例实操教程
IDAJ中国 IDAJ中国
¥9.9
ANSYS SI/PI/EMI&TI 2019 R3 新功能介绍
Ansys中国 Ansys中国
免费
基于有限元方法的整车风噪声仿真分析介绍
基于有限元方法的整车风噪声仿真分析介绍
窃听风吟 窃听风吟
免费
ABAQUS复模态分析
ABAQUS复模态分析
tangxiaocao
¥50
基于workbench的螺丝拧紧过程动力学分析,视频免费无声音,操作细致,建模过程(需购买)
兵荒马乱 兵荒马乱
¥5
